any benefit using 16 instead of 18 guage??
Discussion in 'Loudspeakers' started by TDubbs, Jun 13, 2006.
  1. TDubbs Enthusiast
    TDubbs
    May 4, 2006
    23
    0
    thanks for the help.
    Will be using klipsch khc-6 in ceiling and Sub-10
    with a yammy 659 avr
  2. agarwalro Audioholic Ninja
    agarwalro
    Jan 31, 2005
    3,973
    1,033
    Pittsburgh, PA
    Gauge of the wire used for speaker level connection depends on distance. Longer the distance, lower the AWG (physically thicker wire). IMO, just use 10 to 12 gaure wire for all speaker connections irrespective of distance and you will be fine.
  3. mazersteven Audioholic Spartan
    mazersteven
    Mar 23, 2005
    6,031
    1,431
    Florida
    I agree about using 10-12Awg speaker cable, 14 at the most.
    www.bluejeanscable.com
  4. j_garcia Audioholic Jedi
    Jul 11, 2005
    26,546
    5,726
    10 is usually too big to fit in most binding posts and many connectors, and generally is overkill. 12 will work for pretty much everything most people will ever install, and 14 would be the minimum I would use for anything over 40ft. 18 will almost certainly not cut it, period.
Share This Page
  • CEDIA
