I am new to satellite receivers, but assumed that what I have is the norm for my type of situation. I have two receivers, but each receiver can handle two TVs--one TV is in the room of the receiver and the second receiver is in another room. The receivers have two "sets" of components in them so that the TVs can watch different channels simulataneously. IR is used to control the receiver where the TV is in the same room as the reciver. But, a radio signal is used to transmit and receive the remote control signal from the remote room to the receiver. I assume that this is a VHF signal, but I may not be correct about this, but it is wireless. However, standard COAX connections are used to connect the antennae to the receiver. Because the remote location is on another floor of the house and the house has rock plaster walls, the signal does not reach the remote location very well. Hence my question, how can I help the signal get to and from the remote control to the receiver?
I may have given the impression that the TV signal was transmitted wirelessly, but it is transmitted via COAX. The remote control signal is transmitted wirelessly.
So, can I use the same type of splitter that is used to split a TV signal on COAX? If so, then what? What would I do with the split? I see that boosters are available to amplify a VHF TV signal. but I assume the wireless signal is of a different frequency. Would this help? I cannot feature that my question or problem is that unique.
Thanks
