I'd use an external amp for the center regardless of what you do. 60%-80% of the entire soundtrack is anchored in the surround, and I'm willing to bet its the biggest power hog. Are the surrounds closer to the listening position than the fronts?
The fxi a6 has a sensitivity of 88dB, the a5, 90dB. Let's assume you're 10' from the fronts but 6' from the surrounds, in this case the surrounds have a 3dB advantage at the same power as the fronts, meaning you'd need to double the power for the l/r to match. Its not so cut and dry. It depends on setup and your goal.
Sent from my 5065N using Tapatalk
