I am running a multi-room system (8 speakers) with a Rotel pre-amp and amp rated at 100 watts per channel @4 ohms. The Rotel is a 5.1 system set to front channels only.
The system was cutting out for a few seconds about once per song. I replaced the Niles speaker selection switch and the system still is cutting out but less frequently. Note that I have the pre-amp volume at about 75% of max. Is the amp the problem, and if so what do you recommend. Thanks for the help!
