Hi all,
In searching for setting up for a good audio system, I run into this website and I like the information provided here, so here I am for seeking some help.
I would like to build a system which is reasonably good on listening to classical music(including SACDs), and also be good to play movie.
The room is 13 ft(w) * 19 ft(l)*8.5ft(h). And there are two small windows on the front side along with fireplace that I intended to put TV on this side. Left hand side, there are a big door, and right hand side has two panels of big windows; and the left rear side, there is an openning goes to Kitchen. I am thinking to add a good door or something here to block the kitchen noise.
Currently, the setting is receiver: Onkyo TXNR626(mostly for 4k video upconverting for a 4k TV) with old speakers 5.1 (bundled from old Onkyo THR520 receiver). I have one old pioneer sacd player and one Sony blueray , both play sacds.
2.1 Speakers:
I have auditioned some speakers, and feel like Magnepan 1.7 a lot, except for the bass part.
I am considering to buy
Speakers for 2.1 system:
Maggie 1.7 + SVS SB13 Ultra or
Maggie 1.7 + SVS SB2000
In a room like this, does it make sense to buy Maggie 3.7 or Maggie 1.7 is more than enough?
Considering classical is 80% of time, movie is 20% of time, and I do not go crazy on Bass, will SB13Ultra worth the extra than SB2000?
For surround sound speakers, I am considering add .7 later.
For music amplifier, I am hesitating between
Emotiva XPA-2 and Bryston 4BSST2,
I read about the old version of XPA-2 has hissing noise, how about the 2nd Generation? I read so many good reviews on XPA-2, amazon is giving it 5 stars out of 5. If there is hissing noise, then I wont consider XPA-2. If the music presentation is significantly different, ie, the clarity and positioning is not comparable with Bryston, I will skip XPA-2 also.
For preamp, do I need to buy Conrad-Johnson ET3 or just Emotiva XSP-1 is good enough? I do not want to have one component is an overkill or a roadblock.
If I want to play movie, and using these 2.1 speakers, should I buy a new receiver that have preamp outputs for front speakers and subwoofer, so the stereo amplifier can picked up the front speakers signal?
Any experience? Suggestions?
Thanks a lot in advance.
