Hi,
I have an yamaha micro stereo MCR-755.
The loudspeakers are NS-BP150 with 55-28 KHz and cutoff frequency at 4.5 kHz.
The amplifier has only TREBLE and BASS, with corrections +- 10 DB. I have no information how broad is the effect BASS correction. There is an subwoofer RCA out on the amplifier-
Since the base in the original loudspeakers seemed be quite weak, specially at lower volumes, I bought an yamaha subwoofer YST-SW012 which is an active 8", 28-200 Hz. No frequency controls are provided, just a volume.
However, YST II is the Yamaha Active Servo Technology which enhance probably the bass sound doing it actively more clean.
My dilema is how to set up the BASS (and probably the TREBLE) on the amplifier when the sub is added.
e.g., if the bass setup works over the subwoofer max frequency 200 Hz that would mean that applying correction on BASS will affect parts over 200 Hz which are not compensable from subwoofer. So I risk to create a whole in frequencies over 200 Hz.
On the other side, if I put BASS on +2 or +4 dB that would unnecessary enhance the subwoofer area.
I did some empirical tests. It sounds quite OK but on classic music the base seems to be quite absent.
I also tried to use an frequency analyzer android app on my phone to find out the domain of the BASS control on the amplifier. I could not get a conclusion. Maybe 0 dB correction on base and +12dB on treble should be good.
I read about the crawling technique to find a right place in the living room but nu I need to get an answer about how to leave the BASS control on the amplifier.
I am aware a 700$ stereo is not a HiFi but I would be grateful for some advises.
Thanks!
