Hey there,
My current setup is a single Definitive Technology Supercube II subwoofer in the front left corner. Bass is decent, but I can tell there are some major dips in output probably around 40-50 hertz. I thought about moving the sub to the back left corner as this is where the "subwoofer crawl" gives the strongest bass response. However, it would take a super long subwoofer cable which is a total PITA to keep hidden.
I found another Supercube II on craigslist about 50 miles away from me for $400 so I'm thinking about getting it. My question is since I have pretty good bass response from the single S.C., should I leave it there and place the second one in the back right corner, or should I locate both subs at about the halfway point of the left and right walls?? Could I put the second sub in the front right corner??
I know subwoofer setup/placement is really a lot of trial and error, but I figured it couldn't hurt to pose the question to the members who are running more than 1 sub.
Thanks in advance,
Kyle
