Getting back to the reason for my thread, I'm not getting out of the B&K amp what I had expected or hoped for................I've got two old Optimus amps that I have in mono right now (FL & FR speakers). Upon hooking them up there was immediately an improvement in the overall response from the Axioms. Better bass at normal volume,better separation,etc. I had hoped that a quality unit such as a B&K would be an improvement, however slight that may be. Well, after playing around with my setup(different speakers,front to back, back to front,2 ch stereo,5 ch stereo,etc) this thing might possibly be on par with the power output of my 3300............the overall sound through the B&K is better than the Yammy but the power is no better.
Perhaps my expectations WERE unrealistic. I figured adding a quality piece of gear(albeit older) to my setup would be an improvement. I figured if the cheapee amps improved the sound that much then a B&K amp of similar power would be a bit better. Hey, I don't have a ton of experience behind me in dealing in separates. I realize that some gear isn't necessarily better than others in the same price range, but maybe just different. Perhaps dohanc is on the right track in saying that the input resistance for this amp is just higher than the others I'm dealing with. I don't know so I thought I would bounce this off of all of you in here that have more experience than I.
This is my 1st excursion into gear since before the digital era. I started over about 2 years ago with a Yamaha RX-V620, 4 Klipsch KB1.1's & a cheap Klipsch center & have evolved to this point. I can't( or won't) afford to go out & drop $10K on gear so I'm building (& learning) as I go, hoping not to make any expensive mistakes.
I appreciate all the responses & will take all of the advice into consideration, probably starting by getting a proper power cord for this thing.
Thanks again fellas & if anyone has anything else to relate please do so........
