5.1 BR player, receiver combo
Shrader
Looking to replace the non hdmi dvd receiver in my rv with a br player, needs to be an all in one unit (with speaker/sub outputs) no need for expensive units, just something that has what I need, it is used very little, but I upgraded the TV to a led unit, and have to use analog cables from the cheap coby dvd that is in there now. Anything out there like this? I had a htib once that had a receiver with a built in dvd, would like something like that only with BR. Thanks for any help.
Shrader
Thanks J, that would be what I need, I also did a search on here, but came up empty. Would like to spend less than that if possible, like I said, no need for anything fancy. The fifth wheel is in storage for the winter now, but will need one in the spring.
