4 ohms rated a/v receiver
Discussion in 'Amps, Pre-Pros & Receivers' started by NICKNJ, Dec 29, 2011.
  1. NICKNJ Audiophyte
    NICKNJ
    Dec 25, 2011
    5
    0
    Team,
    I am looking for a/v receivers that supports 4 ohms speakers for ( 5.1 HT).
    I checked Marantz website do not see , it is rated for 4 ohms.
    I do see integra 40.3/50.3 are rates for 4 ohms..
    any suggestion which one to pick.
    price range 800-900 max..
    thanks,
    NJ:)
  2. deedubb Full Audioholic
    deedubb
    Oct 25, 2007
    462
    156
    The Great White North
    harmon/kardon are high current and usually support 4 ohms.
    • Like Like x 1
  3. bikdav Full Audioholic
    bikdav
    Jun 15, 2011
    473
    36
    Andover, MA
    4 ohm amplifiers are very rare. Furthermore, I wouldn't seriously worry about that. Even speakers that are rated at 8 ohms are not 100% truly that and may drop much further than that at many points. Also, any amplifier that truly balked at low impedances would not last on the market very long. That is just plain poor design.
    • Like Like x 1
  4. deedubb Full Audioholic
    deedubb
    Oct 25, 2007
    462
    156
    Years ago when I first bought my PSB Stratus Golds, I had a Sony receiver and it would shut down every time the volume knob approached half maximum. Once I switched to Parasound, all was well again. You're absolutely right that an 8 ohm speaker will drop below that, same goes for a speaker rated 4 ohms. I think it is important to look at that spec in a receiver if you like to play it at relatively high volume.
  5. sholling Audioholic Ninja
    sholling
    Jun 7, 2006
    3,615
    1,023
    Hemet California
    Onkyo's TX-NR709 and above are certified for 4ohm loads. Newegg has the TX-NR809 on sale right now for $650. These run warm so be sure to give it room for air to circulate.
    • Like Like x 1
  6. PENG Audioholic Warlord
    Oct 23, 2004
    8,990
    2,424
    Ontario
    I am sure their older amps were great but don't assume the same with their AVRs. I have seen lab measurements (I posted a couple links before) that showed their models clipped at well below the output of others such as Denon in the same price range. Their protective circuit also would activate rather early, but that may not be a bad thing. They do rate their units more conservatively but you get may be 10 to 25% more relative to others rated (per spec) outputs but that 'likely' won't compensate for the fact that they typically provide lower rated (again, per spec) output than others in the same price range.
    For 4 ohm rated AVR I would stick with Denon AVR-4311, NAD and the higher end Onkyo/Integra models. Even then, if you speakers are really power hungry such as those specified recommended power>150W, adding a 2 ch amp for the L/R speakers will be a safer bet.
    PENG,
    • Like Like x 1
  7. enrique Audioholic
    enrique
    Jun 11, 2005
    231
    13
    miami
    been driving 4ohm speakers with a Marantz for cpl years now 24/7 no problems.Adding an amp i'm sure would may make things easier but thats not allways the case or necessary.
    • Like Like x 1
  8. NICKNJ Audiophyte
    NICKNJ
    Dec 25, 2011
    5
    0
    deedubb,bikdav,sholling,PENG,enrique Thank you verymuch for your feedback..
    I am thinking of placing order for marantz SR6006.Spoke to Marantz tech team and they mentioned it does support 4 ohms speakers.
    based on users feedback( many blogs/forums) it seems many issues with "Integra and Onkyo AVR".
    thank you and Happy New Year.
  9. bikdav Full Audioholic
    bikdav
    Jun 15, 2011
    473
    36
    Andover, MA
    Marantz is a great choice.
  10. j_garcia Audioholic Jedi
    Jul 11, 2005
    27,005
    5,875
    Very few receivers are truly capable of 4 Ohm stability at elevated levels. If you look at the back of any Marantz receiver or amp, ALL of them will say 6 Ohm operation minimum, however I have used 4 Ohm speakers with various Marantz amps and receivers over the years. You just have to be careful about cranking it up.
  11. Knucklehead90 Audioholic
    Knucklehead90
    Jan 20, 2009
    244
    63
    Sunny Central Washington State
    Not all 4 ohm rated speakers are created equal. No mention by the OP of which speakers he owns. I've driven 4 ohm Emotiva speakers with a lowly Onkyo SR-506 when my Onkyo SC-885 needed to be swapped out. For the 2+ weeks I used it to drive my 5.1 setup it didn't get hot and never shut down. Granted - I didn't push it to find the limits of it's capabilities but I didn't baby it either.
    If the OP has easy to drive 4 ohm speakers like the Emotivas he may not need an external amp. On the other hand if he is planning on driving something like Magnepans even the TOTL Onkyo or Denon AVRs probably won't be up to snuff. There are some easy to drive 4 ohm speakers - there are a few difficult to drive speakers - and some in-between speakers.
    IIRC the Emotiva ERTs lowest dip is to 3.2 ohms at some frequencies and actually are over 4 ohms for much of the frequency range.
    The first question should have been: "which speakers are you using - or thinking of using"?
    • Like Like x 1
  12. j_garcia Audioholic Jedi
    Jul 11, 2005
    27,005
    5,875
    Yes, speakers would be a good thing to know, but also need to know if the OP tends to listen very loud and/or has a large room to fill. Even an 8 Ohm speaker can stretch a lesser receiver to its limit if the SPL is high and the room is large.
    My speakers are 4 Ohm, and though they are higher sensitivity (91dB), I tend to listen loud so I added amps. My receiver is 120w and it wasn't enough for the levels I was after in the large room I have.
    • Like Like x 1
  13. NICKNJ Audiophyte
    NICKNJ
    Dec 25, 2011
    5
    0
    Knucklehead90,j_garcia, Thanks for feedback..
    I am going to use for Monitor Audio RX-8 series.
    RX-8 Front
    RX-CX Center
    RX-FX rear
    and Sub -VTF-3 MK4
    thanks,
Share This Page
  • CEDIA
