I'm putting together a back-yard 2 Zone audio system. Zone 1 is for the TV and Zone 2 is for the pool area. The components are listed below. The Onkyo receiver has a 2 Zone system built in but I found out after I purchased it, if you're running in 5.1 for Zone 1, Zone 2 doesn't get any power from the receiver so an additional receiver is required to power Zone 2. My low-cost solution was the AudioSource Amp-100 (50 @ 8ohms) which worked fine for the Zone 2 speakers but did not have enough power to also power the TIC passive sub.
I'm looking for a better amp for Zone 2 that should be able to handle driving the 4 65W 6ohm speakers and the Tic GS-50 8" sub. Not to get too crazy but if it had enough power, I'd add another GS-50 8" somewhere but it's not necessary.
Any advice would be great. I'm looking to spend less than $400 if possible and would like to have 1 AMP for Zone 2 rather than simply buying another Audiosource AMP-100.
INFO:
Receiver
Onkyo HT-RC560 7.2-Channel 3D-Ready Network A/V Receiver with Built-in Bluetooth & Wi-Fi
Zone 1
5.1 Speakers (Center/FR/FL/RR/RL) No Subwoofer in Zone 1
Zone 2
AudioSource AMP-100 Stereo Power Amplifier (Replace this)
4 Yamaha NS-AW390BL 2-Way Indoor/Outdoor Speakers
TIC GS-50 8" 250W Passive Sub
Diagram
Thanks!
