2.1 Home Theather Suggestions
F
fsmdrphed
Hi guys, I want to set up a home theater system in my home actually i want to buy a 5.0 (dali lektor 6 set) but then the place where i will set up changed and now i will put the sytem in a smaller room so what should I buy. 2.1 (with sub) or 2 tower and a center i could not decide. I will mostly use for films and also i will buy a reciver (x2000 denon) can you help me i can reach dali, polk audio, q acoustics wharfedale and magnat products. Thank you in advance
tyhjaarpa
tyhjaarpa
Your room size and budget would help a lot with suggestions. Cant really suggest anything without these.
F
fsmdrphed
So your room is 15' x 20' and total budget is $1,300 for speakers/subs only. Assuming the ceiling is 10', you have 3,000 cubic feet.
You could buy one of these packages.
Thank you so much for your answer
