omac said:
ive been using my pioneer dvd717 for "some" time now and i was thinking of buying a new one.
Does anyone know whats de difference (if any!) between a 10 bit d/a converter and a 12 or 14 bit that come with new players? I know my player is old but Return of the king looks stunning despite that...
I have a panasonic 32" pl10 connected via QED rgb only scart.
PS: my tv cant take progressive (grrrrr..) so will 12 bit make a big diference in picture quality?
Thanks!
I don't know if I fully understand the differences either, but this is my understanding:
The video DAC's convert the digital data from the DVD disc into analog data for your television. The 10 bit vs 12 or 14 bit refers to the sampling (word)size that is used to convert the data. You will also usually see a reference to the speed of the DAC (ie 54MHz or 96MHz). The faster DAC will have a higher sampling rate.
Think of the digital data as a set of stairs. Imagine that the various colors are the depth of the tread (with red having a 1" tread, green having a 2" tread, blue having a 3" tread ect.). Imagine that the larger the "bit" size, the more accurate the measurement is. Consider the speed of the DAC as the height of the steps, with the faster DAC having shorter steps.
If you now draw a line across the edges of the step, and consider that line to be the analog output data, you would get a smoother and more accurate line with the shorter/more exact length (faster/larger bit) steps. Your television then converts that line into the various colors on the screen.
The smoother line should result in fewer color and shadow errors on the picture that you see on the screen.
Since a progressive scan signal has more data than an interlaced signal, the word-length is more critical. 10 bit is usually accurate enough for an interlaced (regular) signal. It will result in very few errors with a progressive scan as well. A 12 bit or 14 bit DAC will have fewer chances of error, but like anything else, you reach a point of diminishing returns.
Try
THIS link to get a more detailed view of what I am trying to say, although it is quite a bit over my head (I'm not an engineer).
If you have a digital connection (DVI/HDMI) between the DVD player and the television, the video DAC's aren't even being used. The player (should be) sending an exact representation of the picture.
