1 output and 2 sets of speaker
Hadi
Hi
I got 2 sets of simple home speakers that have individual power supply and want to make them play with one input from my laptop to get higher power. I was wondering what is best way to do that without reducing sound quality(like audio splitter or connect left and right channel separately to each speaker, as far as I searched) .
1- Sony mini hifi component system (190 watt , 2X6ohms speakers)
2-Perfect Stereo System (40 watt , 2X4ohms speaker)
I hope that someone can help me.
You can split the stereo signal with a splitter/cables easily, it won't reduce sound quality. May not result in the best resultant audio quality by running two stereo pairs simultaneously due to other acoustic issues, but if you're just looking for more volume that might do it.
PS Just what kind of output does your computer have?
PPS You meant you have active speakers, those with their own amps built in?
Mark of Cenla
I have DISH network, and I split the audio out from the DISH receiver. It causes no problem with the sound.
What specifically is the gear you are using, and what is the computer output you are using? The more we know, the more we can help. I happen to like Sony mini systems. Peace and goodwill.
