Open the window. If I had your funds I'd get a Panasonic VT50 or GT50.
JTNY is a forum member in good standing
Looking to buy a new 60" TV , been doing a lot of research and it seems that plasma produces a much better picture relative to the price. Of course the LCDs are nice because they're thin and use less power. My concern is heat issues as myu apartment get's pretty hot and I am concerned about burn-in issues. Anyone have a suggestion on a good 60" plasma/lcd tv? My budget is about $2k.
Past Onkyo, VizioTV, Pioneer 52s-Klipsch Icon-JBL-Wharf-Outlaw, Sony BD, Denon CD, AudioTek Belt Drive/Technic SL-Q300(Shure M97XE-M104E-AT92ECD-112EP-120E cartS), Onkyo Deck, Sony Minidisc, WDTV, Roku, Sirius, URC R50 & Klipsch iGroove SXT All Destroyed By SandyNOW! Vizio 37"-HK 247-Parasound 1000A-OSD 10" Sub-NXG Pro 4.1-Klipsch-RBH-Cables, Ortofon, Sony CA70ES, Panny DMP-BD87-Sony BX59-Roku XS-Oppo 980-TLS Guy 2.0 Vinyl SetupThankS GentS.
ACsGreens (03-09-2013)
Sgratien is a forum member in good standing
Panasonic st series all the way. Burn-in is all but gone these days, although new panels will show some image retention until they get some time on them. The added heat is not that big an issue. And unless the placement gets a ton of direct light- natural or other, plasmas are a no-brainer. Good luck, 60" st series panasonics can be had for about $1600-$1700 right now
Fronts:Madisound RB Kits Rears and Sides: Kef 2001.2, Subwoofer: TC Tiger-1000
Receiver:Onkyo NR-708 Amp: Behringer EP4000 Players: Panasonic BDP-60, Onkyo DX-C390 Projector: Epson 8350 Screen: FAVI PD-HD-92
Funny Quote(s):
That's like trying to get decent sound in a public lavatory.-TLS Guy
Heck, if you've got the cash, go the NSA supercomputer route and use Fluorinert- Adam
A shovel of dirt can stop a flood. -Westom
Please describe your viewing preferences, and your room conditions.
Yes, plasma can produce a better image overall compared to LCD, but LCD is certainly no slouch.
The good:
Plasma: Very good color, excellent contrast, excellent motion handing.
LCD: Very bright, good color saturation, long life without headaches, lower power consumption.
The bad:
Plasma: Potential for burn-in (still, yes, including Panasonic), higher power usage, not as bright, reflective glass.
LCD: Not as good off angle viewing, not as good contrast, not as good with motion.
Generally, I feel that anyone who cares about video quality should end up with at least one good plasma in their system from Panasonic or Samsung (not LG!)
But, if you can only have one TV and you will be playing a ton of games or leaving static images up on the screen all day long, and you are in a room that is very bright with large windows that aren't shaded, then perhaps a LCD is best for your situation.
I have installed both, I own both, I like both. But, I review every home and situation I go into with the intent to deliver the proper display for that specific person. So, you need to determine what will make you happiest in the long term, not simply what will produce the best image.... Unless of course that's what WILL make you happiest in the long term. Then, just get a plasma. Panasonic ST plasmas at 60 or 65 inches are excellent. The VT series is marginally better. I would stick with the ST at this time.
AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
Pyrrho (03-20-2013)
I own a Pany GT60 Plasma and a ST plasma ( never ever had a burn in issues )
I say buy what your wallet can afford and what you like. These days its hard not to find a decent picture from a Pany or a Samsung. For a good deal right now, as BMX noted find yourself a ST Pany plasma as the deals are everywhere.
#1 Vincent Sp-331mkII amp, ATI 2002, Quicksilver's Mid Mono amplifier(2), Wyred for Sound STP-SE, (pre-amp), Rogue 99 Pre-amp, Jolida JD-9A, Micro Seiki bl-91, Kef 104.2, Usher be718, Rega Apollo, Sony xA5400ES, #2 Win7, Synology DS413 NAS w/Seagate 4 -2TB HHD, JRiver17, EE DAC Plus, Mytek DSD DAC, Genelec 8030A,Kef140
: #3 HT; Denon 4311Ci,GE Triton 2's, Sat50C, Sat3's, Rythmik D15se, OPPO-95,
Also nobody ever seems to mention that plasma's buzz. Apparently some people hear it and some don't. I never knew this until I bought one. Not a huge deal but it does bug me a bit sometimes. Awesome picture though.
Samsung 64" 3D Plasma
Emotiva UMC-1
Emotiva XPA-5
Onkyo M-501
Playstation 3
Samsung BD-P1600 BD player
Boston VR2 fronts
Boston VR12 center
Boston VRX side surrounds
Boston CR9 rear surrounds
Rythmik Servo-12" Sealed, built by Guy Audio, Me![]()
DIY sub with 15" CSS sub and dual 18" PR's
Behringer EP4000
Elemental Designs eQ2
Belkin PF31
Motion issues are a thing of the past for a quality LCD panel these days, just like the life expectancy of a plasma is considerably longer than before and they are far better at burn-in resistance (though as mentioned, not immune).
HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
Are you sure which side of the glass you are on?
Grador is looking for a job at AH
HT: Samsung LN32B460 32" LCD (greyscale calibrated) | AVR: Yamaha RX-V765 | L/R: Emp E55Ti | C: Paradigm Center 1 | Rears: Sony Junk | SW: Klipsch RW-10d miniDSP | Sources: Acer Revo Ion running XBMC with mySQL library server and 4 TB HDD, PS3, Technics SL-Q2 TT | 2x Aura Pro Bass Shakers
Bookshelf: Yamaha RX-V992 | Paradigm Mini Monitors
Shelved for now: Paradigm 11 SE Deluxe
starmaster is a forum member in good standing
One thing you might want to also consider is that plasmas actually "flicker" somewhat which can cause eye strain (like it did for me). That is why I switched to an LCD screen. LCD is getting way better now. Plasma is dying out.
