Results 1 to 2 of 2
Thread: Atdec Quick Shift Donut Display Mount First Look
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Atdec Quick Shift Donut Display Mount First Look
    Want a nearly tool-less display mount with nearly unlimited adjustments? Atdec has what you want with the new Quick Shift Donut. A integrated level moves the display up and down and side to side. A wrench releases a ball joint to move 40 degrees plus rotate. A button releases the display from the mount. Adjustable? We'd say so.
    Discuss "Atdec Quick Shift Donut Display Mount First Look" here. Read the article.
  2. #2
    ned
    ned is offline Full Audioholic ned is gaining some recognition
    Join Date
    Jul 2004
    Posts
    352
    Thanks Given
    33
    Thanks Received
    8
    Default
    Great for Speaker mounting as well.
    Front: NOW RBH 1266 SER, 661 LSE modified, 61 LSE, 441 se, 641 se
    Rears: RBH 66se, 41se
    SUB: SVS, Emo
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
