Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com MonoPrice.com
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > CD/DVD/Blu-ray & Misc Hardware
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #31
Old 11-05-2009, 01:51 AM
Seth=L Seth=L is offline
Seth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened toSeth=L should be listened to
Default
test post to test thread stability....
__________________
Be bored.
  #32
Old 11-05-2009, 09:43 AM
WmAx's Avatar
WmAx WmAx is online now
WmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened toWmAx should be listened to
Default
Quote:
Originally Posted by woofersus View Post
Yes, that's true, but I wasn't necessarily trying to start that debate. Just subjective opinions on my part. I'm at least objective enough in my comparisons of gear to admit that. I do believe that accross the lineup they don't all sound the same though.
And I don't think anyone ever said they sound the same across the line up. You always have those units with poor anti-alias filter design, odd up-sampling algorythms and other factors that end up coloring the output. But it's easy for any company to design a neutral unit, and at low price, if they really cared.
You may be more likely to run across the highest percentage of neutral units in the so-called 'mid-fi' category, where manufacturers are not trying to play silly feature games usually, have sufficient budget to make quality/reliable units and usually, only highly qualified technically oriented electronic engineers are more likely to be designing the units, as opposed to some audiophile oriented nutjob designer.
-Chris
__________________
Dedicated to improving the real[quantifiable] parameters of sound reproduction.
The Following User Says Thank You to WmAx For This Useful Post:
PENG (11-07-2009)
  #33
Old 11-09-2009, 07:56 PM
Boerd Boerd is offline
Boerd is a forum member in good standing
Default
Quote:
Originally Posted by JDawg View Post
I have an old Teac PD-D1200 cd player that I've been using for about the last 15 years. Then I started reading about more expensive cd players such as Cambridge Audio Azur 640C, Rotel 1072 or the NAD C542. So I was just wondering if these cd players would be a noticeable improvement over what I have right now or do all cd players sound the same?
I own a 5 years old "El Cheapo" DVD player with 24/96 DAC for movies (60$) and a SqueezeBox3 about 2 years old (299$) with 24/48 DAC for audio and I cannot tell the difference for the life in me...
The only reason I like the digital WIFI player better (the SqueezeBox) is that it has no mechanic noise from spinning the CD and even if you put your ear close to it, it doesn't have electrical hum so in the evening or nights when the volume is low I can hear only music.
Between two CD/DVD players I could never tell the difference - maybe let's say one is mechanically noisier than the other (you may hear the CD spinning like my DVD player).
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2007 AUDIOHOLICS, LLC
