Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com MonoPrice.com
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > Televisions & Displays
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 01-05-2006, 01:49 AM
cerf cerf is offline
cerf is a forum member in good standing
Question Green halo with sony KD-34XBR960 CRT TV
I have a 2 month old Sony HD TV, hooked up to a Yamaha RX 2600 and an HD Tivo. Recently, I've been getting a greenish "halo" maybe 6-8 inches thick around the perimeter of the picture. Tonight it was bluish. It usually went away if I turned the TV off then on. Tonight I had to leave the TV off for> 30 seconds to get rid of the bluish halo. I love the TV, and would hate to have to take it to a rapair station. It took three strong people to lift it onto a three foot stand! Any idea what's going on?? Thanks
  #2
Old 01-05-2006, 12:30 PM
beam3 beam3 is offline
beam3 is a forum member in good standing
Default
I've read that many people have had issues with the tube on the 960, not exactly sure on the specifics. That was the main reason why I bought the HS420 instead. Good luck, I'm sure if you search the net you'll find the reasoning behind it.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2007 AUDIOHOLICS, LLC
