Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com MonoPrice.com
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > Loudspeakers
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 11-21-2002, 09:06 PM
Posts: n/a
Default
I am looking for a set of four identical speakers for my parents that will allow them to enjoy a lower end 5.1 system.  What are considered good speakers for around $300 for a set of four?  They need to be around 10" high.
I'll be pushing them with low to moderate power (80 to 100 watts (50 or so continuous).
Lee
  #2
Old 11-21-2002, 11:13 PM
RLA's Avatar
RLA RLA is offline
RLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AHRLA is looking for a job at AH
Default
Hi
Four speakers for a 5.1 system? you need 5 speaker+ the subwoofer  mix and match speakers are not a good way to go either.That is a pretty low power receiver  also
I would reccomend you look at the Klipsch Quintet system
with the KSW10 subwoofer    They are Compac,Elegant
and very easy to drive as they have high sensitivity
They sound a lot bigger than they are with excellent dynamics needed for good HomeTheater
www.klipsch.com
look under  home audio synergy system
Ray
__________________
Your Inland Empire THX Certified Dealer/Installer
www.rlahometheater.com
  #3
Old 11-22-2002, 02:41 PM
Clint DeBoer's Avatar
Clint DeBoer Clint DeBoer is offline
Administrator
Clint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened to
Default
I agree, matching 4 speakers to another-branded center channel would not be the best choice.
__________________
Clint DeBoer
Editor in Chief
Audioholics
  #4
Old 11-30-2002, 01:10 PM
Posts: n/a
Default
I also agree not to mix and match speaker brands regarding
5.1, 6.1, or 7.1 systems. Check out the Paradigm Cinema series for the best performance at an affordable price.
Hank
  #5
Old 03-24-2003, 10:13 PM
littleb littleb is offline
littleb is a forum member in good standing
Default
Quote:
Guest : I am looking for a set of four identical speakers for my parents that will allow them to enjoy a lower end 5.1 system. *What are considered good speakers for around $300 for a set of four? *They need to be around 10" high.
Lee
Check out the Pioneer ISO series speakers.  They are low end audiophile product.  I have the sdf3k's, which is 17" high.  Check out the sdf2k or sdf1k.  The sdf3k were rated #1 by CR.  I have them and am satisfied.  I don't think they are the best speaker, but they are a good, warm sounding speaker.  A good value.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2007 AUDIOHOLICS, LLC
