Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com MonoPrice.com
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > CD/DVD/Blu-ray & Misc Hardware
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 11-12-2003, 01:03 PM
Clint DeBoer's Avatar
Clint DeBoer Clint DeBoer is online now
Administrator
Clint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened toClint DeBoer should be listened to
Default
I can't tell you how long I've been searching for home theater furniture that could handle the particular design and layout specifications of my Reference System 3.
After looking high and low, I came across a vendor whose products looked very promising. Real wood, high capacity, flexible options. We decided to take a closer look and see if the product was as good in actual use as it looked online.
The results were far better than we even expected.
[Read the Review]
__________________
Clint DeBoer
Editor in Chief
Audioholics
  #2
Old 11-13-2003, 02:08 AM
Posts: n/a
Default
I'm interested in how open systems like these are with regards to everyday household dust.  On one hand I guess being open they are pretty easy to reach in and clean, but obviously they also allow more dust in to get on and in expensive components in the first place.  I have always had AV racks etc. with glass doors on the front and even they allowed a fair amount of dust inside. What's your opinion?  How bad is dust that gets inside for these expensive systems actually?  Is it just a cosmetic issue, or can it advesely effect the interior components?
  #3
Old 11-13-2003, 10:23 AM
Administrator
Default
Good question. I actually think the increased heat dissipation helps the components more than the dust hurts them. There is a fair amount of surface dust on the shelving after a couple of weeks, but we take care of that with a swiffer duster - real quick and easy.
With all of the component swapping around I do, it might not hurt to open up chassis every year or so to check them out, but overall I would think this is a non-issue - except for aesthetics of having to dust the glass, etc.
I actually love how I don't have to mess around now to gain access to my components.
__________________
Clint DeBoer
Editor in Chief
Audioholics
  #4
Old 11-13-2003, 02:25 PM
Posts: n/a
Default
I have the 8082 and I concur this is the best value on the market.  I looked hard at Bello, Sanus, Salamander, Billy Bags and others and no one even came close to offering the same number of shelves, weight-capcity/shelf, and decor.  BDI should be the frst place you look if you are in market for HT furniture.
They are a bit pricey but places like Unique Style Solutions offer very good prices and in my case free shipping which is a huge savings.
The stand is very accomodating and solid it does not vibrate at all and even has wheels to aid when you ahve to move it.  On top of all that the wire mangement makes the wires very incospicuous.  Highly Reccomended!!Unique Style Solutions
  #5
Old 11-14-2003, 12:20 AM
Paul F Paul F is offline
Paul F is a forum member in good standing
Default
Hi Aaron,
Nice referral, but what gives? *When I tried to find BDI products under "audio stands", "tv stands" and "entertainment centers" -  on that link, they aren't listed! *Found lots of mirrors etc. when I did a search on "bdi" but even when I did a search on "bdi 8082" it still came back with no results!!! ???
  #6
Old 11-14-2003, 02:45 AM
Administrator
Default
Paul,
I couldn't find furniture there either... Go here and enter your zip code.
__________________
Clint DeBoer
Editor in Chief
Audioholics
  #7
Old 11-17-2003, 11:37 AM
PaulF PaulF is offline
PaulF is gaining some recognition
Default
Clint,
Very nice. Matches your speakers perfectly. I especially like the rounded inside corners of the front face.
I have a custom made Billy Bags open design rack. It can support the space shuttle but it lacks the nice cable management of the BDI. (I couldn't pass up a bargain. I sent BB my custom design on another store's graph paper, they mistakenly quoted me distributor pricing, I paid $1000 for a $1700 rack even though I told them the truth.)
There seems to two holes in the rear panel for cable access, top and bottom. I assume there is routing space between the intermediate glass shelves and the inside of the back panel for routing cables to the holes. Is this correct?
BTW, is that a piano you have your projector on? The piano and mirror also match the system. Was that a fluke?
Edit: sorry, forgot to note there was no mention of list price.
Also please note I should not be confused with the other unregistered Paul F.
  #8
Old 12-01-2003, 12:57 AM
Default
Thanks hawke for the link!  This is seriously nice AV furniture.
PaulF - Hi!  I registered this way the same day I posted my first 'unregistered' post - it's the same way I'm registered on other boards I'm a member of.  I understand you not wanting confusion, and as I'm the newer member, if this is causing you angst I'll gladly re-register with another user name -ok?
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright 2007 AUDIOHOLICS, LLC
