Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Bass Management Basics – Settings Made Simple
  1. #51
    cjsxv2 is offline Audiophyte cjsxv2 is a forum member in good standing
    Join Date
    Aug 2009
    Location
    KS
    Posts
    8
    Thanks Given
    2
    Thanks Received
    0
    Default Set Up Help
    Figured this would be the best place to post my questions.
    I have 7.1 system consisting of: Yamaha 3800, Fronts/Rears/Surrounds - Paradigm 100s v2 (All 6 speakers are 100s), Center - Paradigm CC-690 v4, Sub - Def Tech Trinity.
    I am having problems setting up the crossover points. I simply allowed the receivers auto setp to calibrate everything in the past but lately Ive been jacking around with it and Im curious what everyones opinion is. All the speakers are set to lrge.... I run LFE to the sub and have it crossed over on the receiver at 60hz. Ive messed with the receiver settings some, and I believe Ive set each channel's crossover to 60hz, matching the sub crossover on the receiver.
    So my questions are: a)should I set my speakers to small, b) what should I set the crossover on the receiver to and what should the crossover on the sub itself be set to or does it matter as Im running LFE and c) Does setting the speakers to 60hz on the Yamaha 3800 actually mean Im setting the speakers crossover at 60hz?
  2. #52
    AVRat's Avatar
    AVRat is offline Audioholic Ninja AVRat should be listened to
    Join Date
    Jun 2005
    Location
    Colorado Springs, CO
    Posts
    3,790
    Thanks Given
    353
    Thanks Received
    680
    Default
    a) Set all to small
    b) Set receiver to 80 Hz, sub x-over doesn't matter using LFE input since it's bypassed.
    c) Yes, if speakers are set to small. The x-over point only affects the speakers set to small. If set to large, the speakers receive the full frequency spectrum.
    Mitsubishi LaserVue L75-A91, Denon AVR-4810CI, Oppo BDP-83, Escient FireBall MX-111, APC H15
    Speakers: L/R - ESS AMT Monitor, Def Tech ProCenter C2, UIW BP In-wall, UIW 64 In-ceiling, Dual SVS PB12-PLUS, Def Tech SuperCube I
    Zone 2 (3 Areas through Niles HUB8, Niles MSU-480, Niles TS-110 Table Top Sensor & 3 x Niles IM/VC w/IR sensor)
    Paradigm CS60R In-ceiling 2 Pair
    Exterior -- Backyard Patio
    Paradigm Stylus 250
  3. #53
    Join Date
    Aug 2009
    Location
    KS
    Posts
    8
    Thanks Given
    2
    Thanks Received
    0
    Default
    Since I currently have the speakers set to lrg, that means theyre running full range. So then where does the lower frequency bass go to that the speakers cant handle. For the 100s I believe they go down to 38hz..... so does that mean anything below that the sub gets, or anything below that just doesnt get heard? How does the receiver determine what to send to the sub and only the sub, if the speakers are set to full range(large)
  4. #54
    AVRat's Avatar
    Join Date
    Jun 2005
    Location
    Posts
    3,790
    Thanks Given
    353
    Thanks Received
    680
    Default
    If the speakers can't produce the frequency at a hearable level you won't hear it. With all speakers set to large, the only signal the sub produces is the discrete LFE siignal.
    Paradigm Stylus 250
  5. The Following User Says Thank You to AVRat For This Useful Post:
    cjsxv2 (08-28-2009)
  6. #55
    JAMS is offline Junior Audioholic JAMS is a forum member in good standing
    Join Date
    Jun 2009
    Location
    hampton va.
    Posts
    93
    Thanks Given
    38
    Thanks Received
    5
    Smile X/OVER 80hz does wonders
    I was advised to set all small and 80hz,whew what a difference,it came alive,i did have too adjust the sub x/over too 75hz because it was over lapping the front spkrs bass right at 80hz too exsenuated ,now the bass sub comes in evenly as the fronts fade out,a smooth transition is happening now!
    Ive heard wierd stuff happens on x/over when used on subs and receivers,but it was perfect on mine!!! Usual setup is the receiver does the x/over with subs x/over set to max about 150hz!
    GOOD LUCK, JAMS
    avrs pioneer vsx1016 nad t765, dvd ps3,oppo 971h,amps audiosource amp 200,spkrs,infinity beta 50s,beta 20s,bic america ht-63,subs velo vx-10 and jbl psw1000
  7. The Following User Says Thank You to JAMS For This Useful Post:
    cjsxv2 (08-28-2009)
  8. #56
    nate88818 is offline Audiophyte nate88818 is a forum member in good standing
    Join Date
    Mar 2004
    Posts
    8
    Thanks Given
    0
    Thanks Received
    0
    Default Help With Mirage OM-8's and Denon AVR-4806ci
    My setup:
    Mirage:
    Mains - OM-8 28Hz-22kHz
    Center - OM-C2 38Hz-22kHz
    Surrounds - OM-R2 80Hz-kHz
    sub - OM-200
    Denon 4806ci
    As of now I have all set to small THX 80hz crossover, my question is about the OM-8's
    They have powered subs in them, should I be setting these to large?
    Thanks
  9. #57
    maclick is offline Audiophyte maclick is a forum member in good standing
    Join Date
    Sep 2011
    Location
    Mesquite TX
    Posts
    4
    Thanks Given
    3
    Thanks Received
    1
    Default
    Great read, my Tannoy's have a Frequency response of - 6dB, so should I put my crossover setting at 120hz?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
