I do metal framing and can tell you that mounting edge banded 3/4" piece of plywood (spray painted flat black) that spans 3 studs and anchoring your mount to that won't be a problem. You would want to pre-drill and counter sink the plywood and be careful not to strip out the screws but I'm sure you can imagine that 3 or 4 screws in each stud totaling 9-12 screws all together would hold up pretty much anything.
In the end you owe the landlord the very minimal wall prep and some touch up paint ... or even the paint for the whole wall. Hardly a consideration when weighed against good sound.
BTW, nice place and nice gear.
LinkBack URL
About LinkBacks
