Results 1 to 10 of 10
Thread: Building a Music Room
  1. #1
    jcmusic is offline Audiophyte jcmusic is a forum member in good standing
    Join Date
    Dec 2009
    Posts
    5
    Thanks Given
    2
    Thanks Received
    0
    Default Building a Music Room
    Hi Guys,
    This is my first post here so please try and help me out!!! I am getting ready to build a dedicated 2 channel listening room and want some advice on the acoustics. The room will be 19.5X13X8 with one stndard size window and one door. I am curious about the ceiling can I use something on top of the sheetrock? Any and all adivce will be appreciated!!! Oh yea!!! the speakers will be on the short wall, they are Klipsch corner horns with SET power!!!
    Jay
  2. #2
    bpape is offline Audioholic Chief bpape should be listened to
    Join Date
    Jan 2005
    Location
    Wildwood, MO (St. Louis)
    Posts
    935
    Thanks Given
    2
    Thanks Received
    145
    Default
    Hi Jay - welcome
    The cavity above the drywall in the ceiling should be insulated. While that won't damp anything in the room, it will allow the sheetrock and cavity to provide a little midbass control and stop it from ringing like a drum.
    Where is the door and window in relation to the length and width of the room?
    Bryan
    Lead Acoustical Designer
    GIK Acoustics
    I am serious and don't call me Shirley.
  3. #3
    Join Date
    Dec 2009
    Posts
    5
    Thanks Given
    2
    Thanks Received
    0
    Default
    Quote Originally Posted by bpape View Post
    Hi Jay - welcome
    Bryan
    Hi Bryan,
    Thanks for replying, the window will more than likely be on the one of the long walls, and the door on the rear wall. Thanks for your help.
    Jay
  4. #4
    Join Date
    Jan 2005
    Location
    Posts
    935
    Thanks Given
    2
    Thanks Received
    145
    Default
    Can you be a little more specific? Middle of the walls? Toward the corners? Try to keep them away from front corners of the room and the window away from your reflection points.
    In general, you'll want some broadband bass control in the front corners and reflection panels on the sides at a minimum. Depending on speaker type and location to the boundaries, etc. nothing, absorption, or diffusion behind the speakers may be in order.
    Rear wall - again, depends on how everything else falls whether you'll need bass control in the middle of that to deal with bass nulls.
    Diffusion on the rear half of the side walls is always a nice thing if budget will allow.
    Bryan
    GIK Acoustics
  5. #5
    Join Date
    Dec 2009
    Posts
    5
    Thanks Given
    2
    Thanks Received
    0
    Default
    Bryan
    Bryan,
    In my first post I say there that my speakers are Klipsch Conrner horns, so that covers the front corners. I am thinking mid-way to toward the rear for the bookcases.
    Jay
  6. #6
    Join Date
    Jan 2005
    Location
    Posts
    935
    Thanks Given
    2
    Thanks Received
    145
    Default
    Sorry about that. With Khorns in the front, you'll want some absorption middle of the front wall and at the side wall reflections. Broadband bass control in the rear corners.
    With an 8' ceiling, you'll likely also want something relatively thick directly over the listening position.
    Bryan
    GIK Acoustics
  7. The Following User Says Thank You to bpape For This Useful Post:
    jcmusic (12-15-2009)
  8. #7
    Join Date
    Dec 2009
    Posts
    5
    Thanks Given
    2
    Thanks Received
    0
    Default
    Bryan
    Ok Bryan,
    I am thinking about setting up my gear as it is in it's current room, that would put the equipment rack in the center between the speakers. Is this going to create problems?
    Jay
  9. #8
    Join Date
    Jan 2005
    Location
    Posts
    935
    Thanks Given
    2
    Thanks Received
    145
    Default
    If you can use a low, wide rack, it should be OK. That's always a good idea anyway no matter where it is just to keep it below the listening axis.
    Bryan
    GIK Acoustics
  10. The Following User Says Thank You to bpape For This Useful Post:
    jcmusic (12-16-2009)
  11. #9
    Join Date
    Dec 2009
    Posts
    5
    Thanks Given
    2
    Thanks Received
    0
    Default
    Ok Bryan,
    Now one more thing, what type of materials should I use in the construction of the room? Anything really a must? Or can I just use standard building materials and then treat the room?
    Jay
  12. #10
    Join Date
    Jan 2005
    Location
    Posts
    935
    Thanks Given
    2
    Thanks Received
    145
    Default
    It all depends on how far you want to go in terms of isolation.
    For the ultimate - Room in a room with walls decoupled with DC-04 clips, either floating joists or RSIC-1 with hat channel on the ceiling. Double drywall with Green Glue. All HVAC isolated. All outlets and switches and lights boxed around. Float a floor. Make sure you use a solid core wood door.
    Something like that will give you an EXTREMELY low noise floor in the room allowing for excellent dynamic range possibilities, and the ability to hear way down into the details once the room is properly treated.
    Bryan
    GIK Acoustics
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
