Results 1 to 9 of 9
Thread: Auralex Room Analysis Plus Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Auralex Room Analysis Plus Review
    Acoustics. Next to your speakers, your room is probably the biggest contributor to the quality of the sound. We here at Audioholics care about acoustics as we understand that it is one of the major factors affecting your listening experience. The Auralex Room Analysis Plus gives you the ability to not only get recommendations about treating your room, but a report based on ACTUAL MEASUREMENTS! And it doesn't cost thousands of dollars either.
    Discuss "Auralex Room Analysis Plus Review" here. Read the article.
  2. #2
    squire.10@osu.e is offline Audioholic Intern squire.10@osu.e is a forum member in good standing
    Join Date
    Mar 2006
    Posts
    34
    Thanks Given
    0
    Thanks Received
    0
    Default
    So....where's the review? Am I missing something?
  3. #3
    mperfct's Avatar
    mperfct is offline Audioholic Samurai mperfct should be listened to
    Join Date
    May 2007
    Location
    in the anaerobic zone.
    Posts
    2,029
    Thanks Given
    933
    Thanks Received
    677
    Default
    Quote Originally Posted by squire.10@osu.e View Post
    +1. Where's the beef?
  4. #4
    GlocksRock's Avatar
    GlocksRock is online now Audioholic Spartan GlocksRock should be listened to
    Join Date
    Oct 2005
    Location
    Charlotte, NC
    Posts
    6,136
    Thanks Given
    287
    Thanks Received
    910
    Default
    Yeah, I want to read up on this...
    SHARP Aquos LC70LE640U
    Denon AVR-4311ci, Emotiva IPS-1
    APC H15 Power Conditioner
    PS3, Wii, XBOX 360 Elite Slim
    Dell Inspiron 660 HTPC
    Def Tech BP7001SC, CLR3000, BPX, BP10, BP2X
    SVS PB13-Ultra on Great Gramma
    Harmony One
    Bedroom System
    Samsung PN58C590
    Explorer 4250 HD cable box
    Yamaha RX-V1800 Onkyo M-5140 amp
    Xbox 360 Elite, PS3 Slim
    Dell Vostro 400 HTPC
    Def Tech BP7006, CLR2300, BPX
    SVS PC12 Ultra & 20-39PC+ on Subdude HD
    Panamax M8-HT-Pro
    Harmony One
  5. #5
    gene's Avatar
    gene is offline Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default
    Its fixed now. Check it again. thx.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  6. #6
    fredk is offline Audioholic General fredk should be listened to
    Join Date
    Jan 2008
    Posts
    1,289
    Thanks Given
    137
    Thanks Received
    259
    Default
    Bass trapping in the corner: as much as you can. Absorbtion/diffusion at first reflection points.
    This is the standard advice you see in most posts asking for room treatment help. Every room will benefit from these basic treatments.
    In fact, if you go onto forums for people setting up in home recording studios, the advice is much the same.
    As intriguing an idea as this service is, if you are going to spend money, spend it on treatments.
    If you are inclined to see what your rooms acoustic profile, download REW (freeware), pick up the mic etc. and measure AND graph to your hearts content. Spend some of that $250 on your significant other so she is more likely to tolerate your obsession.
    Fred
    "Given time, we can come to believe that many different variations on the truth are apparently equally entertaining." - Floyd E. Toole
    _____________________
    Axiom M80 mains, Qs8 surrounds, dual M2 centers, EP350 sub, Sony 50A2020 display, Denon 2808 AVR
  7. #7
    Weasel9992 is offline Junior Audioholic Weasel9992 is gaining some recognition
    Join Date
    May 2008
    Location
    Savannah, GA
    Posts
    51
    Thanks Given
    5
    Thanks Received
    11
    Default
    I'd kinda have to agree with Fred here. I mean, it's a good thing to know the specific issues in any room, but it's not terribly relevant in most cases because the solution will be the same in all but the most unusual cases. After all the basics are covered in terms of room treatments, then measurements become useful in terms of finding the nagging problems, and avoiding over treating one particular area or another.
    Frank
    Frank Oesterheld
    GIK Acoustics
    www.gikacoustics.com
  8. #8
    Join Date
    Jan 2008
    Posts
    1,289
    Thanks Given
    137
    Thanks Received
    259
    Default
    An article on the thing that most influences sound quality (after the speaker) and... silence...
    Fred
  9. #9
    bsaxman is offline Audiophyte bsaxman is a forum member in good standing
    Join Date
    Jul 2009
    Location
    BC, Canada
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Anyone try this product?
    Anyone try this product yet? I might try the free version without the mic. The thought of having to record the sweep is daunting (I don't have any recording devices except an ancient circa 1985 Sony tape deck) so I anticipate it will be frustrating for me.
    My issue is that I have an almost perfectly square room, concrete floors, and the ceiling is dropped down to about 7 ft across the front and along one side (a basement room with bulkheads for HVAC and plumbing) so I'm thinking the room will definitely need to be tamed.
    Does anyone know if the microphone can be plugged into the 'mic in' on a laptop and use Sound Recorder or something like that to record the sweep?
    Heck does Windows Vista even still have Sound Recorder? ....well if not, I'm sure there's freeware somewhere and Google might rescue me (again!)
    Comments?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
