admin should be listened to
The Sanus System CFA56 is quite a substantial piece of furniture. You definitely will feel like you got your $850 out of it. It is heavy, has built in "convection-style" cooling, easy access to your gear from the removable back panel, and bottom exit of wires. It is easily put together by a single person though it is not the easiest piece of furniture you'll ever assemble. The aesthetics are very good with a fairly high quality vinyl wrap over some quality pieces of MDF.
Discuss "Sanus System CFA56 AV Cabinet Review" here. Read the article.
