Results 1 to 5 of 5
Thread: Projector flicker
  1. #1
    panteragstk's Avatar
    panteragstk is offline Full Audioholic panteragstk is quite helpful
    Join Date
    Aug 2012
    Location
    Texas
    Posts
    391
    Thanks Given
    27
    Thanks Received
    101
    Default Projector flicker
    As the title states my projector has decided to randomly flicker. I know it is the PJ because it has the problem on test patterns that are built into the projector with no source attached. If I tap the side of the PJ, it stops. Also, it only starts if I'm using it for a few hours, in the first few hours it doesn't happen.
    I've never seen this before and only have 1500 hours on the PJ and bulb. I'm thinking that the bulb is going prematurely. Anyone else ever seen this?
    Projector is a Mitsubishi HC4000 connected to an APC UPS to protect the bulb. Any other thoughts as to what could be the cause other than the bulb?
    Home Theater:
    Receiver: Onkyo TX-NR809
    Speakers: Pioneer SP-FS52 LCR, and Kenwood HTIB speakers for surround, Cambridge Soundworks for the surround back
    Subs: Dual Infinity 1262w sealed
    Sub Amp: Crown XLS1500 775w X2 @ 2ohms
    Sources: PS3 and custom HTPC running SageTV client
    Projector/Screen: Mitsubishi HC-4000, DIY 120" AT screen
  2. #2
    BMXTRIX's Avatar
    BMXTRIX is online now Audioholic Spartan BMXTRIX should be listened to
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,792
    Thanks Given
    343
    Thanks Received
    1,310
    Default
    I've heard of lamp flicker before. Nobody seems to be able to say why it occurs exactly, but if the projector is under warranty, then I would call Mits about it.
    I will add, 1,500 hours may be under the 'normal' amount listed, but is very typical for a lamp to end its useful life. I generally recommend that people budget for a new lamp at 1,000 hours. Lamps dim significantly over time and at any point after 1,000 hours people often find that the quality of the image suffers significantly due to this dimming.
    AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
  3. #3
    just-some-guy's Avatar
    just-some-guy is offline Audioholic Field Marshall just-some-guy should be listened to
    Join Date
    Sep 2007
    Location
    sw sub chicago
    Posts
    1,659
    Thanks Given
    163
    Thanks Received
    235
    Default
    open up the projector. unplug & replug(at least several times per connection) all connections you can find. including the bulb.
    ViewSonic Precision Pro8100, 119" HP 2.8
    Panasonic BD35
    PIONEER VSX 01TXH ... XPA-3
    SWANS 6.1 & C3 rosewood, RVSS sides
    EP2500, DCX2496 & dual CSS SD12's
  4. #4
    Join Date
    Aug 2012
    Location
    Texas
    Posts
    391
    Thanks Given
    27
    Thanks Received
    101
    Default Re: Projector flicker
    As strange as this sounds, it seems to have stopped. Wondering if my UPS is to blame.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    Home Theater:
  5. #5
    Join Date
    Sep 2007
    Location
    sw sub chicago
    Posts
    1,659
    Thanks Given
    163
    Thanks Received
    235
    Default
    yeah, well, don't count on it. my pj is acting up. never did it. then a hint of problems. then BAMMMM, couldn't even use it. then the next day, like it never happened. now, its acting up a little again. and mine has low hrs on it, 550.
    Panasonic BD35
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
