Results 1 to 6 of 6
Thread: BenQ W1070 and W1080ST Projectors Preview
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow BenQ W1070 and W1080ST Projectors Preview
    BenQ is attempting to set some new price barriers for home theater projectors. The new W1070 and W1080ST projectors are priced at $1,099 and $1299 respectively. The W1070 is a 1080p 3D DLP model that uses Dark Chip 3 (DC3). In the past, this chipset was used for high-end models only. The W1080ST is a short-throw 1080p 3D model that lets users enjoy a big screen experience even if their room isn't big on space. Both projectors support NVIDIA 3DTV Play, DLP Link, and dual HDMI. Designed with DLP’s DC3 technology, both projectors feature a 10,000:1 contrast ratio and, oddly enough, built-in 2-watt stereo speakers.
    Discuss "BenQ W1070 and W1080ST Projectors Preview" here. Read the article.
  2. #2
    BMXTRIX's Avatar
    BMXTRIX is offline Audioholic Spartan BMXTRIX should be listened to
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,314
    Default
    Need to get a real hands on review of this, but it has been long overdue for ANYONE to put out a short throw 1080p model designed more around home theater use. The big problem with some of the BenQ models is that the ones not designed for home theater really miss the mark on color accuracy, noise control, and quality in general. They always worry me as a company until some people take them for a test ride and have them in their homes for a few months at least. I'm certainly not going to gamble before any reviews our out, but a short throw 1080p 3D for under $1,500 seems like it could really hit the mark for a lot of people.
    AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
  3. #3
    Swerve's Avatar
    Swerve is offline Junior Audioholic Swerve has a small fan club
    Join Date
    Jan 2009
    Location
    Vancouver, BC
    Posts
    73
    Thanks Given
    22
    Thanks Received
    12
    Default
    the W1070 really is a short throw. It won't work for me at 20' on a 106" screen according to benq's site and projectorcentral.com
    Cave build Onkyo HT-RC270, Jamo C607, C60CEN, C601 Highs, C60SUR, A102 SurBacks, SUB300 X2
    Monoprice 7337 106" Screen, Sony KP-51WS500 CRT RPTV, Shaw Gateway/Arris MG5225G & MP2000 HD Cable, , Sammy BD, JVC XV-FA95 DVD, Harmony 880
    WTB: Panny AR100
    Lvrm Yamaha HTR-5750, Energy RC-Mini Fr&R, RC-Mini Center, e-XLS8 Sub
    Samsung PN63C550, Arris MP2000, PS3 Slim 250GB, Boxee Box, Harmony One, Harmony PS3 adapter
    Bdrm JVC HTIB DVD, Energy Take2 F&R, Take1, Sony HTIB Sub, JVC 24", Arris MP2000
  4. #4
    BMXTRIX's Avatar
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,314
    Default
    Quote Originally Posted by Swerve View Post
    A short throw is anywhere between .1 and .7 times the screen width. If you can hit a 100" wide image from 70" or less then it is definitely short throw.
    A typical throw range is about 1.2 to 1.5 times the screen width. So, a projector which can hit 100" diagonal from about 12' away is 'typical'.
    Now, both projectors have a short zoom RANGE, that is, you don't get a lot of play with their zoom range. They are not 'super zoom' projectors like the Panasonic AR100 or the Epson 8350 which can go a great distance from the screen and still hit a smaller size.
    This may be what is troubling you, but that does not make the 1070 a short throw projector. The W1070 can throw a 100" diagonal from 8'4" to 10'11", which is 'typical' for a projector.
    In comparison, the Optoma HD33 can throw a 100" diagonal from 10'11" to 13'1" which is also 'typical' for this type of projector.
    Now, in comparison, the BenQ W1080ST throws a 100" diagonal from 5' to 6' away from the screen. That's often perfect for someone who has to put a projector in front of a soffit, or a ceiling fan and still wants a larger image. In fact, it is the first home theater 1080p model which is remotely affordable which can do this.
    Now, in all fairness, the W1070 is shorter throw than similar models such as the Mitubishi HC4000, Viewsonic Pro8200, or Acer H6500, but not much. Those projectors start at around 10' for a 100" diagonal, and go to 13 to 15' throw. But, not one of them can hit a 106" diagonal from 20' away. For that you need a super zoom projector, or a model with a long throw lens.
    Edit: Just wanted to add, that while there are dozens of 1080p projectors under $2,000, there are only FOUR which can throw a 106" diagonal from 19' lens to screen (assuming 20' to your back wall, so, a foot less for the projector depth).
    http://www.projectorcentral.com/proj...sort=pop&sz=15
    Clearly 20' to 106" is a long way, and is outside the 'norm' for most projectors in that price range.
    From 11 feet, 16 projectors can do 106" diagonal, including the W1070.
  5. The Following User Says Thank You to BMXTRIX For This Useful Post:
    Swerve (03-22-2013)
  6. #5
    Swerve's Avatar
    Join Date
    Jan 2009
    Location
    Vancouver, BC
    Posts
    73
    Thanks Given
    22
    Thanks Received
    12
    Default
    I just can't mount it any closer to the screen without infringing on the wife's minimum standards for aesthetics. Bumping the budget up to 2500 introduces 6 more, but the Panasonic AR100 still sits at the top of my list. I don't want 3D, and for my first projector, I think it'll do just fine for quite some time.
    WTB: Panny AR100
  7. #6
    BMXTRIX's Avatar
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,314
    Default
    Both the AR100 and Epson's 8350 are great models of projectors which will make you very happy. They aren't in the same class as the AE8000 or 5020 or the JVC RS46 models of projectors, but at half the price, they certainly do a very good job.
    DLP has really dropped the ball IMO in comparison to what LCD manufacturers have done with their ultra flexible placement options. I mean, both the AR100 and 8350 models offer lens shift as well as the super-zoom capabilities which will really help with your placement options.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
