admin should be listened to
InFocus announced the release of two new constant-duty commercial projectors in their IN5300 series. The projectors can allow a variety of inputs and sources and there are 3 lens options. With a small form factor and a rich feature set, both the IN5312 and IN5314 seem perfectly suited for large classrooms, conference rooms, or houses of worship. The two new projectors are nearly identical but they differ in realized lumen output and native resolution (the IN5312 is XGA and 4500 lumens and the IN5314 is WXGA and 4000 lumens). Three different lens choices are possible, including a standard zoom lens, short throw lens and long throw lens. The projectors also have horizontal and vertical lens shift, which is almost unheard of at this price with DLP and means custom installers can position the image exactly where it needs to be, or even offset the project a bit as needed to compensate for placement limitations.
Discuss "Infocus IN5312 and IN5314 DLP Projectors Preview" here. Read the article.
