Results 1 to 6 of 6
Thread: Optoma HD66 DLP 3D Projector Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Optoma HD66 DLP 3D Projector Review
    The Optoma HD66 is a 3D ready projector for those that are into 3D gaming. While Blu-ray and broadcast 3D are not supported, gaming is another story. And for $700, the HD66 is a 720p projector that has tons of setup features, a full suite of calibration controls, great color, and decent black levels. You may have to fiddle with it a bit to get the most out of it, but for a dedicated Audioholic, this is a great entry-level projector.
    Discuss "Optoma HD66 DLP 3D Projector Review" here. Read the article.
  2. The Following User Says Thank You to admin For This Useful Post:
    krzywica (07-07-2010)
  3. #2
    krzywica's Avatar
    krzywica is offline Audioholic Samurai krzywica should be listened to
    Join Date
    Feb 2005
    Location
    Milwaukee WI
    Posts
    2,237
    Thanks Given
    736
    Thanks Received
    605
    Default
    Cool....this would be a nice starting point for me...
    Main HT Trakt
    Yamaha RX-V663, HTPC, PSB (T55, C60), Emotiva UPA2, Velo SMS-1, Panasoic 50" 1080p Plasma
  4. #3
    LXIX is offline Audiophyte LXIX is a forum member in good standing
    Join Date
    Feb 2006
    Posts
    7
    Thanks Given
    0
    Thanks Received
    2
    Default
    In your review you go to great lengths to mention the fact that you can only use this projector with a PC for 3D.
    Are you aware of the fact that the Panasonic BDT300 and BDT350 3D BD players can output their BD signal over HDMI in a checkerboard pattern? I am fairly certain that this will allow this projector to display a 3D image from a new format 3D BD disc.
    I am guessing you would need to have a pair of 3D glasses with DLP link as well.
    Your thoughts?
  5. #4
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    These projectors are EXTREMELY finicky with how they do 3D. I had an Acer in for review several weeks back and it never truly worked correctly. I would have very little confidence in the HD66 working with any 3D BD player apart from its specific design parameters.
    Clint DeBoer
    Editor in Chief
    Audioholics
  6. #5
    BMXTRIX's Avatar
    BMXTRIX is offline Audioholic Spartan BMXTRIX should be listened to
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,794
    Thanks Given
    344
    Thanks Received
    1,315
    Default
    The whole world of BD-3D is not getting properly addressed by projector manufacturers and it's extremely frustrating to see ANY projectors badged as '3D' when the format that is garnering the most attention right now is the new BD-3D specification.
    I do know that LG was showing off all of their 3D capable projectors at Infocomm hooked up to their 3D Blu-ray players at the show. I mean, EVERY projector which could do it was running Blu-ray, not the nVidia card and a PC. It was extremely cool to see them using sub $1,000 projectors with Blu-ray without any hiccups.
    There are some great 720p projectors out there and the HD66 is a solid entry level projector, but I wouldn't buy it for the 3D aspect unless I was sticking with the nVidia card solution.
    It sure would be nice to see some reviewers with nVidia cards, and some 3D BD players start to test and try out the new 3D projectors.
    AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
  7. #6
    TRoher is offline Audiophyte TRoher is a forum member in good standing
    Join Date
    Jul 2010
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Projectors & 3D
    The BD - 3D specs that were published earlier this year changed the playing field, and the industry is still playing catch up. The HD66 was released prior to the BD specs, so it does not meet those requirements. The HD66's 3D capability claim was based on its 120 Hz refresh rate and ability to handle the 3D signals used at that time and the use of active glasses.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
