admin should be listened to
Continuing our look at presentation projectors, we took a look at the Sanyo PLC-WLC500L, a unique dual lamp system that is designed for flexible installation, high (5000) lumen output and extended run-time that means you won't have to replace the bulbs until after 6000 hours. The projector is a WXGA model, meaning it has a resolution of 1280x800 (16:10) which is compatible with most widescreen laptops and computer monitors. This makes it a perfect match for presentations – that is, if you can fit it under your arm to your next appointment!
Discuss "Sanyo PLC-WTC500L LCD Multimedia Projector Review" here. Read the article.
finishers is off the scale
