admin should be listened to
Optoma has upped the bar with their release of the HD20. This sub $1k projector is full 1080p, has more than enough inputs for most applications, and gets you into a front projection system for an unbeatable price. Value shop for a power retractable screen and a mount and you're only out around $1700. I know lots of people that have paid that (and more) for a 50" flat panel. At this price, if it turns on it's pretty much a success. Well, I'll spare you the suspense - it turns on.
Discuss "Optoma HD20 DLP Projector Review" here. Read the article.
Fronts:Madisound RB Kits Rears and Sides: Kef 2001.2, Subwoofer: TC Tiger-1000
Receiver:Onkyo NR-708 Amp: Behringer EP4000 Players: Panasonic BDP-60, Onkyo DX-C390 Projector: Epson 8350 Screen: FAVI PD-HD-92
Funny Quote(s):
That's like trying to get decent sound in a public lavatory.-TLS Guy
Heck, if you've got the cash, go the NSA supercomputer route and use Fluorinert- Adam
A shovel of dirt can stop a flood. -Westom
As is always the case, I can't let a projector review go by without some comments...
1. Would love to see a picture of the remote control in the review.
2. The rest of the pictures looked pretty solid.
3. For the pirce, the typical 1.2x zoom lens is common, but compared to almost every other projector which costs a bit more, 1.2x is very weak. Placement flexibility with this projector stinks - really, REALLY bad!
4. It would have been nice to see some actual placement measurements. The offset of the HD20 is less than most other fixed lens projectors, so people with lower ceilings (7' basement!) can have an easier time of it (maybe) because they don't have to lower the screen as much. Likewise, the zoom range may be very poor for anything but ceiling mouting because it likely falls right at the proper seating distance. Which would place a noisy projector right between two viewers. Blech!
5. No Blu-ray source is listed. Really, BD is becoming a standard for those who care about quality and front projection really benefits from this (perhaps the most) technology. Since many will hook up the projector to a BD player with BD video, it is worth discussing just how much better/worse BD is compared to DVD with cheaper players and a direct HDMI connection, or a connection which bypasses the 4310's excellent scaling. Really, HD cable was listed, but not discussed either. A bit more discussion of personal experience using the best sources would really help people understand the quality potential of this unit.
6. 4x color wheel vs. competition. BenQ also has a 1080p $1,000 model. My understanding is that the Optoma has a 4x color wheel vs. the BenQs 2x color wheel. This provides a significant reduction to the Rainbow Effect (RBE) for those who are sensitive and considering competitors products.
7. Competitors? Really, it's good to mention that there are competitors out there which should be considered or evaluated as well. Would be better to get some reviews in so they can all be compared to each other.
Solid review overall! The Optoma is a value leader and tends to produce solidly reliable products. Their huge jump to minimize lens offset really opens up this projector for additional rooms which older models like their H31 or HD70 couldn't handle. For example, with a 100" screen, the HD70 had almost 18" of offset from the top of the screen. That requires a 100" screen to be almost 2' below the ceiling and, with a 100" screen and a 7' ceiling, would put the bottom of the screen about 1' from the floor! The HD20, for the same 100" diagonal, only has about 8" of offset which gives about another 10" away from the floor in the same setup and is far more ideal overall for many less expensive setups.
Note: That 100" diagonal puts the projector lens about 11 to 13 feet from the screen which is right where seating is. Go with the ceiling mount.
FINALLY: The commentary on spending $200 for someone to install it is really disappointing. A basic installation similar to a cruddy cable company job would have all surface mounted cabling and would take hours to accomplish and would not include cabling or any proper setup calibration or anything... Especially with a motorized screen which typically requires two installers to handle. If someone is on a serious budget, install it yourself. If you want a good installation, then pay for an in-wall installation with speakers, etc. and plan to spend the money for two pros to do the job in about a full day. So, about 16 hours of professional labor... which will be over $200 typically, depending on your location, likely well over $200. Don't forget to budget for appropriate cabling, sound, etc.
AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
Thanks Tom for the review, however I'd like to see a bit more objective tests (aka measurements) on color/grays & black reproduction.
I think without these this review is like speakers review with FR/Impedance graphs
Lucky decent measurement tools are inexpensive (like X-Rite Eye-One Display 2), but to truly impress bunch of AHer something like Eye One Pro would truly welcome.
TV: TC-P55ST30 , AVR: TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub, Netgear NeoTV 550, Harmony 880 URC RFS200, PC->Toslink-> Audioengine D1->JBL LSR2325P
When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
shadyJ is off the scale
I have been running the Optoma HD20 for a few months now and I really love it. It is my first projection system though, so I don't have anything else to judge it by, so I can't tell you how it fares against other projectors.
There is hardly any rainbow effect, the only movie I ever noticed that on was the Blu Ray of The Wild Bunch, and I think that had more to do with the source than the projector. The colors are terrific, as is the brightness, I couldn't ask for anything more in those depts. The black levels are not bad, and my understanding is that you will have to pay a lot more than $1K to get better black levels. I think that a grey screen would be a better fit for this projector than a white one, if I were to redo my theater I would use a grey screen with this projector instead of white. I made my own screen out of Wilson Art designer white counter top laminate, it is a 125" 16:9 screen, in a room with pretty good light control. Everyone who has seen my home theater says I should charge admission!
I still have some more tweaking to do, but at the moment I am blown away by this setup. Think about this, I went from a standard definition 32" tv with two channel sound to a 125" 1080p picture with a 5.1 Infinity Primus surround sound system and Hsu VTF3 subwoofer! As you might imagine, I watch a lot more movies now. I have spent too much on blu rays in the past few months, I went from zero titles to maybe 80 or 90. I don't know how much money that is in movies, and I am afraid to add it up! I never had that many standard definition DVD's, Laserdiscs, or VHS, and to get them all in such a short time, this is as bad as any spiraling drug addiction- call for help, someone!
jostenmeat (03-01-2010)
08op is gaining some recognition
shady j, where is your optoma mounted,ceiling, and how far from it are you? how bad is fan noise during quite movie parts? i am thinking of picking one up and going to do the same screen w/ wilsonart DW.
epson 705hd
yahama rxv-465
lg bd 370
polk tsi 400
polk cs10
polk ti15
klipsch rw-12d
logitech harmony 550
The projector is ceiling mounted and about 17' back. I have no idea what the review is talking about regarding fan noise. This thing is near silent. You have to be right next to it to hear anything. There are some modes where the fan will ramp up it's RPM, but you wouldn't normally be viewing those modes anyway as they are for certain circumstances and really shorten the life of the bulb.
By the way, the wilson art screen works great, but if I were you, I would go with the fashion grey instead of the designer white, I think that will improve the black levels substantially. Also, it took wilson art a month to deliver the laminate, just a heads up for you.
thanks for info shady, i was getting nervous about buying beacuse i keep hearing about loud fans on them. about the DW, is your room light controlled or do you have light in there?, my room can be pitch black, and i read its better to use DW than gray in light controlled rooms.
epson 705hd
yahama rxv-465
lg bd 370
polk tsi 400
polk cs10
polk ti15
klipsch rw-12d
My room is light controlled fairly well, probably better than most home theaters. From what I have read, gray screens are good for both high and low levels of ambient light, whereas white is good for just low light levels. I think the gray would improve the black levels, which, while not bad, is probably the Optoma's weak point.
The wilson art laminate has made a terrific screen. Tell me, how big are you planning on making the screen? What sort of framing are you going to be doing? Will you be doing a backboard?
Hopefully you are already aware of hometheatershack.com's projection screen forum, which I have found to be a great resource. AVSforum's projector screen forum has also been incredibly helpful.
i guess i'll read more then decide on gray or DW. i plan on doing about 110-120" for size and making a frame out of 1x4 with two braces in middle, screwing board to frame and 3" velvet border. my room will be completley light controlled.
epson 705hd
yahama rxv-465
lg bd 370
polk tsi 400
polk cs10
polk ti15
klipsch rw-12d
