The BenQ 1080p projectors have a longer throw lens which generally doesn't make them hit 106" diagonal from the distance you are looking at.
http://www.projectorcentral.com/proj...s=106&sort=pop
There are 22 projectors which can do it, the BenQ is just not one of them.
I'm throwing the same size from about the same distance, so I know the BenQs have issue from that distance/size.
Personally, I would go with the Epson.
LinkBack URL
About LinkBacks
