Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: BenQ W5000 DLP Projector Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow BenQ W5000 DLP Projector Review
    If you think you're having a hard time deciding which projector is the best, think about my job... I actually get to see, use, and calibrate most of them and yet I still have a hard time determining which is "best". Let me tell you that I do NOT envy the job manufacturers of projectors have these days. The market is ripe with bargains and price points are all but written in stone, with very clear distinctions between $1000, $2500, and $5000 models - all of which are competing for consumers' wallets. BenQ is clearly going after the custom installer market with its new W5000 DLP projector and that's good - because it gives them some leeway that wouldn't be granted for those pursuing consumers directly.
    Discuss "BenQ W5000 DLP Projector Review" here. Read the article.
  2. #2
    f300v10 is offline Enthusiast f300v10 is a forum member in good standing
    Join Date
    Jul 2008
    Posts
    11
    Thanks Given
    0
    Thanks Received
    2
    Default
    Nice review of the W5000. Having read many of your projector reviews I have noticed you sometimes publish contrast numbers, and sometimes not. Any chance you could post CR measurements on the W5000?
    Also, some other reviews have indicated the W5000 suffers from an image noise problem on HD sources. As you pointed out, the noise reduction menu on the W5000 does not function on HD resolution sources. Owners of the W5000 have differing views on this issue, some claim the 'noise' is just film grain that the sharpness of the W5000 reveals. Your review did not mention any noise problems, so I was wondering if you noticed this issue?
  3. #3
    Join Date
    Jul 2008
    Posts
    11
    Thanks Given
    0
    Thanks Received
    2
    Default
    Also, what version of the firmware was your sample using? With version 1.08 the overscan cannot be set to zero. With versions 1.12 or 1.21, it can be.
  4. #4
    BMXTRIX's Avatar
    BMXTRIX is online now Audioholic Spartan BMXTRIX should be listened to
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,312
    Default
    I've gotta say that I've had horrible luck with BenQ when I purchased a W10000 for a client. The projector has now been replaced 4 (or 5?) times with a different issue every time. This includes the color wheel exploding, the projector comletely dying, and then the PS3 not being recognized via HDMI.
    I also don't know if BenQ has addressed the issue of the projector not having discrete power on/off commands for use with even the most basic of universal remotes. I know the W10000 did not have this, so it was very inconsistent handling projector power.
    The serial port, unless things have changed, works okay, but once again, discrete power control for the projector doesn't exist! That's right, despite the full ability to have it report status, and provide true two-way control of the projector, BenQ's engineers simply didn't include it and even skipped over basic discrete functionality.
    Lastly, there are two things that bug me about the review in particular.
    1. Why not discuss lens shift? People talk all the time about zom range, and say things like "You get a 100" digaonal from 10 to 12.5 feet", but then they don't say, "You have zero lens shift" or "vertical lens shift only allows you to put the projector as high as the top edge of the screen".
    Since this projector has a limited zoom range, the lens shift becomes that much more important for room placement. If you can't get the projector above the top of the screen then it may interfere with rooms with high ceilings or with tiered seating.
    2. Ergonimcs or Ease Of Setup? Which one does the zoom range and lens shift fall into and why did both of these get five stars when the competing LCD models at that price offer 1.6-2.0:1 zoom range and often have lens shift which exceeds screen height? This projector may offer many settings after you get it out of the box, and may offer a lot to affect image quality in a good way, but it is NOT secondary when you can't get the projector into your room in the first place! I think it's a huge drawback to this projector, but I do realize that it is a huge perk over the non-lens shift Optomas which may come in at a similar price. There's just no way that it is deserving of more than 3 stars in one of those sections based upon the far less than average setup capabilities for placement. Really, it would be 2 stars which can be brought up by some other features IMO.
    Just things that are worth pointing out. Oh, and the current BenQ, which did have a weird power issue which seems to have gone away, looks awesome. Absolutely stunning with 1080p/24 material on BD - bright, punchy, and vibrant. I just feel like I have to keep my fingers crossed for it to keep working.
    AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
  5. #5
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Quote Originally Posted by f300v10 View Post
    From what I can tell, despite requests to the contrary I was running 1.08.
    Quote Originally Posted by BMXTRIX View Post
    I actually did.
    BenQ offers powered Zoom and lens shift. Also, no one should be buying this projector unless it fits their room and screen - and that's hardly a negative, especially when the chosen lens offers such a crisp picture. As always, reviews have a subjective element, but there's at least a solid reason for why I give the marks I do.
    I actually forgot to include this from my notes, but Lowering Detail Enhancement down to "2" or "1" (the default is "5") dramatically reduced the amount of noise in images.
    Clint DeBoer
    Editor in Chief
    Audioholics
  6. #6
    Join Date
    Jul 2008
    Posts
    11
    Thanks Given
    0
    Thanks Received
    2
    Default
    Actually the W5000 can be 20% of screen height above the top of the screen, the lens shift is +120/-80.
  7. #7
    Join Date
    Jul 2008
    Posts
    11
    Thanks Given
    0
    Thanks Received
    2
    Default
    Quote Originally Posted by Clint DeBoer View Post
    Clint, did the lower value result in any visible loss in picture sharpness or detail?
  8. #8
    Reorx is offline Full Audioholic Reorx is gaining some recognition
    Join Date
    Mar 2005
    Posts
    426
    Thanks Given
    20
    Thanks Received
    19
    Default
    Nice review.
    What was the actual lumens output once the projector was properly calibrated?
    At $5000, I'd expect the lens to be interchangable. So I could add a short throw, long throw, or just a different lens. There are a few really good lens companies out there.
    Display: Panasonic TC-P65VT50
    Receiver: Yamaha HTR-5760
    Speakers: 6x ElectroVoice FR12-2
    Center: JBL Sound Power SP222
    Amps: Ashly FTX-2100 ; Yamaha PS2075
  9. #9
    ned
    ned is offline Full Audioholic ned is gaining some recognition
    Join Date
    Jul 2004
    Posts
    352
    Thanks Given
    33
    Thanks Received
    8
    Default
    Generally DLP machines tend to offer less zoom than an LCD however w5000 seems to be in the lower end.
    Front: NOW RBH 1266 SER, 661 LSE modified, 61 LSE, 441 se, 641 se
    Rears: RBH 66se, 41se
    SUB: SVS, Emo
  10. #10
    Join Date
    Jul 2002
    Location
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    That's going to be subjective, but I'd say no "real" definition was lost. It certainly didn't blur the picture. It just got rid of the noise issue. Some people will want more detail enhancement, but I felt it detracted from the image.
    Clint DeBoer
    Editor in Chief
    Audioholics
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
