Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Panasonic PT-AX100U LCD Projector Review
  1. #1
    gene's Avatar
    gene is offline Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default Panasonic PT-AX100U LCD Projector Review
    audioholics.com/productreviews/avhardware/Panasonic-PT-AX100U.php">[proj]The PT-AX100U is every bit as enticing as the preceding model - more so if you figure in the fact that this projector comes with better initial calibration, better benchmark scores and an improved lamp with plenty of lumen output. On top of that it is debuting at $200 less than the starting MSRP of the PT-AE900U. If you are looking for an LCD projector that will take you into the big screen experience for a reasonable amount of money I don't see how the Panasonic wouldn't make the top of your shopping list.
    [audioholics.com/productreviews/avhardware/Panasonic-PT-AX100U.php">Read the Review   [amp;bannerid=209&zoneid=&source=&de st=http://www.visualapex.com/audioholics/default.asp?SE=Audioholics&KW=PT-AX100U_Review">Get a Special Price from VisualApex!]
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  2. #2
    Hi Ho's Avatar
    Hi Ho is offline Audioholic Samurai Hi Ho should be listened to
    Join Date
    Sep 2005
    Location
    Washington State
    Posts
    2,254
    Thanks Given
    8
    Thanks Received
    297
    Default
    Excellent review! I keep thinking about projectors but I have been since I started researching the AE700 when it was new. Someday I might actually buy one. The Panasonic models keep getting better!
    You just had to include that Sunday Night Football game didn't you.... That was just a bad game...
    URC MX-980 Remote with MRF-350 RF Base Station / Monoprice 4x2 HDMI Matrix / Yamaha RX-V2700 / Panasonic DMP-BD60 Blu-Ray / HTPC with Ceton InfiniTV 4 CableCard Tuner / Xbox 360 / Panasonic TC-P54G25 1080p Plasma / Mitsubishi HD-1000 Projector / 92" FAVI Motorized Screen / DIY Speakers and Rythmik Audio DS1500 Sub
  3. #3
    Davidt1 is offline Full Audioholic Davidt1 is gaining some recognition
    Join Date
    Nov 2005
    Location
    Houston, TX
    Posts
    301
    Thanks Given
    59
    Thanks Received
    13
    Default
    Thanks for the review. No special pricing on the AX100 at VA though .
  4. #4
    Clint DeBoer's Avatar
    Clint DeBoer is offline Administrator Clint DeBoer should be listened to
    Join Date
    Jul 2002
    Location
    Lakeland, Florida, United States
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Quote Originally Posted by Hi Ho
    Miserable game... It's cool to see the quarterback has really matured though. I would not have thought 'da Bears' would have been able to do what they did.
    Clint DeBoer
    Editor in Chief
    Audioholics
  5. #5
    therealgiblet is offline Audiophyte therealgiblet is a forum member in good standing
    Join Date
    Oct 2006
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Does this projector handle Xbox 360 games well?
    See above o_O
  6. #6
    jcPanny's Avatar
    jcPanny is offline Audioholic Ninja jcPanny is considered a mentor
    Join Date
    May 2005
    Posts
    3,830
    Thanks Given
    13
    Thanks Received
    200
    Lightbulb Great review
    Great review of the new Panny! It is exciting to see the front projection products getting better and cheaper every year.
    Gene,
    I think you need to edit this paragraph to refer to the AE900U and AE100U models, both of which have the D5 panel.
    "Let's get a quick overview of the highlights (those of you familiar with the PT-AE700U will recognize most of these). In addition to the D5 panel specifications shown earlier, the AE900U features:"
  7. #7
    Join Date
    Jul 2002
    Location
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Quote Originally Posted by jcPanny
    Great catch - that was a hold out sentence that shouldn't have been there...
    Clint DeBoer
    Editor in Chief
    Audioholics
  8. #8
    jigesh is offline Enthusiast jigesh is a forum member in good standing
    Join Date
    Jan 2006
    Posts
    17
    Thanks Given
    0
    Thanks Received
    0
    Default
    Some of the screenshots (like those of Menu and the ones from "House" with red-wall in the background) show "blockiness" which I assume is due to JPEG compression effects on the photographs and were not visible on the projector screen.
    Great review; Thanks!
    By the way, you mention you used Denon 3930 - so I guess its review is also in the offing!!
    Jigesh
  9. #9
    Join Date
    Jul 2002
    Location
    Posts
    6,153
    Thanks Given
    509
    Thanks Received
    805
    Default
    Quote Originally Posted by jigesh
    Yes, compression artifacts.
    Clint DeBoer
    Editor in Chief
    Audioholics
  10. #10
    ned
    ned is offline Full Audioholic ned is gaining some recognition
    Join Date
    Jul 2004
    Posts
    352
    Thanks Given
    33
    Thanks Received
    8
    Default
    Projector manufacturers needs to take a lesson from Panasonic - we need a bright projector >2000 ANSI lumens. The recent 1080p are quite anemic. BTW, can the light harmonizer be manualy overiden?
    Front: NOW RBH 1266 SER, 661 LSE modified, 61 LSE, 441 se, 641 se
    Rears: RBH 66se, 41se
    SUB: SVS, Emo
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
