Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Optoma HD72 DLP Projector Review
  1. #1
    gene's Avatar
    gene is online now Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,818
    Thanks Given
    819
    Thanks Received
    2,401
    Default Optoma HD72 DLP Projector Review
    audioholics.com/productreviews/avhardware/OptomaHD72p1.php">[hd72]The Optoma HD72 projector produced incredibly sharp, well-defined images. It also has some of the best colors and black levels we have seen in a projector under $3500.  The projector’s input flexibility, impressive feature set, and styling are things normally found on projectors at much higher price points. Optoma’s impressive two-year warranty and no dead pixel policy make this an easy recommendation. It simply blows our mind that the consumer can now purchase this level of performance for $2000.
    [Read the Review]     [amp;itmname=Optoma%2BHD72?si d=PAUD">Get Special AH Pricing from Projector People]
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  2. #2
    cthomp is offline Junior Audioholic cthomp is a forum member in good standing
    Join Date
    Feb 2006
    Posts
    80
    Thanks Given
    0
    Thanks Received
    0
    Default Thanks for the review
    Thanks for the great review Gene. I am torn between the HD72 and the Sony
    HS51A. Tough choice in my book.
  3. #3
    RLA's Avatar
    RLA
    RLA is offline Audioholic Chief RLA is looking for a job at AH
    Join Date
    Aug 2002
    Posts
    962
    Thanks Given
    0
    Thanks Received
    6
    Default
    Hello
    If you are not sensitive to RBE and your room can accommodate the HD-72's offset this is a relatively easy choice IMOHO
    Your Inland Empire THX Certified Dealer/Installer
    www.rlahometheater.com
  4. #4
    jeffsg4mac's Avatar
    jeffsg4mac is offline Audioholic Samurai jeffsg4mac should be listened to
    Join Date
    Dec 2003
    Location
    Chichester, NH
    Posts
    2,705
    Thanks Given
    933
    Thanks Received
    548
    Default
    Good job Ray, but damn that offset pisses me off. I will have to go with the panny because my ceilings are 7.9 ft and I want a 100in screen at least.
    "Somewhere in Kenya, a village is missing its idiot!" - Unknown
    http://theconservativepatriot.me/
  5. #5
    RLA's Avatar
    RLA
    Join Date
    Aug 2002
    Posts
    962
    Thanks Given
    0
    Thanks Received
    6
    Default
    7.9 and a 100-inch diagonal may work if you play with the throw distances. If you can make the HD-72 work you will be laughing all the way to the bank
    And your fellow 1280x720p LCD friends will be drooling over your install
  6. #6
    Join Date
    Feb 2006
    Posts
    80
    Thanks Given
    0
    Thanks Received
    0
    Default Maybe even a 106 with 7.5
    I think it would even be possible to do a 106 in a 7.5. The HD72 has a 6.52 degrees offset that requires it to be about 16.9" form center of lens to the top of the viewing surface. (Depending on throw distance). Using a low profile ceiling mount would put the center of lens at about 7". So 7 plus 16.9 puts the top of the viewing surface at about 24". Using a 106"d screen (52"H viewing surface) would leave you about 14" from the bottom of the screen to the floor. This puts the center of the screen at about 40" which is pretty close to eye level sitting in a chair or couch. I would agree that this is a little lower than I would prefer, but if the HD72 is as good as it sounds, I would be willing to give it a try!
    PS: There is more on this topic at the following:
    http://www.projectorreviews.com/Manu...erformance.asp
  7. #7
    jeffsg4mac's Avatar
    Join Date
    Dec 2003
    Location
    Chichester, NH
    Posts
    2,705
    Thanks Given
    933
    Thanks Received
    548
    Default
    That is just not going to work in my room at all. Room dimensions are H=7ft10in L=25 W=13.5. I have a acoustic panel on the ceiling that is 4in thick and is suspended about 3in from the ceiling. I need about 18 to 20in height for my center channel with its stand. I would really like a 106 to 110 in screen. Is this an issue with all DLP projectors or just this model?
    Going by the link there, if I use a 100in screen, it would be something like this. 23in from ceiling to allow for offset and to clear my panel, and about 18in from off the floor. Center of screen about 44.5in up. Or am I thinking about this wrong? Do I need to worry about the hanging panal at all. Is the offset going to cause the projector to project past it even though the lens would be aiming almost even with it if I mounted 6in from the ceiling? I can post some pics later if you want to see how it is setup. I would really, really like this to get this projector. I saw it playing at CES this year and it was awesome.
  8. #8
    RLA's Avatar
    RLA
    Join Date
    Aug 2002
    Posts
    962
    Thanks Given
    0
    Thanks Received
    6
    Default
    Hello All
    Jeff,
    The Optoma has a rather extreme offset 106" screen with this PJ with standard ceiling height would be difficult because of where the screen would need to be placed for the center channel. Look at the Infocus IN 76 or 7210 PM,e-mail or call me before you proceed there may be other alternatives.
  9. #9
    jeffsg4mac's Avatar
    Join Date
    Dec 2003
    Location
    Chichester, NH
    Posts
    2,705
    Thanks Given
    933
    Thanks Received
    548
    Default
    Quote Originally Posted by RLA
    Hello All
    Jeff,
    Will do, thanks
  10. #10
    Ajbolit is offline Enthusiast Ajbolit is a forum member in good standing
    Join Date
    Mar 2006
    Posts
    15
    Thanks Given
    0
    Thanks Received
    0
    Default
    Hi, any recommendations for a screen? I can accomodate up to 120" diagonal in my basement. Any problems wiht "light splatter"? Should I get a "no gain" screen for that projector?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
