Results 1 to 4 of 4
Thread: I have Sweet speakers but can't use them! help a brotha out
  1. #1
    Kazanovitz is offline Audiophyte Kazanovitz is a forum member in good standing
    Join Date
    Jul 2012
    Posts
    3
    Thanks Given
    0
    Thanks Received
    0
    Question I have Sweet speakers but can't use them! help a brotha out
    I have a Pioneer vsx-521 is in my Living room with a blu ray and cable input.
    I have four 201 Bose direct/reflecting speakers. How should i plug them into the surround sound to get the best quality sound?, should i get another speaker? i am scared of shorting my amp because my bose require so much power.
    And how can i just play music on the system. If i plug an RCA to aux chord into it and then in my ipod it only plays on one speaker.
    My blu ray has a usb port i was thinking of utilizing this to use all the speakers. I really have no idea though. Help me out if you can!
  2. #2
    gene's Avatar
    gene is online now Supreme Audioholics Overlord gene should be listened to
    Join Date
    Jul 2002
    Location
    Florida
    Posts
    5,820
    Thanks Given
    819
    Thanks Received
    2,402
    Default
    If you only have 4 speakers, you should plug two of them to the Main front channels and two of them to the surround channels of your receiver. Then turn off the center and surround back channels. Calibrate the 4 speakers using the internal test tones and an SPL meter. You can run 4CH stereo when listening to CD's or MP3s for more impact. Peruse the Audioholics Editorial site for more setup tips.
    Down the road you may want to upgrade your speakers and add a powered sub for more bass impact.
    Good luck.
    Gene DellaSala
    President, Audioholics
    Pursuing the truth in audio & video...
  3. #3
    jonnythan's Avatar
    jonnythan is online now Audioholic Ninja jonnythan should be listened to
    Join Date
    Jan 2006
    Posts
    3,054
    Thanks Given
    103
    Thanks Received
    415
    Default
    Those speakers are decent for music, but you might not be happy with them for home theater use. The whole direct/reflecting thing and mediocre frequency response make it hard to understand voices.
    -Jon
  4. #4
    Adam's Avatar
    Adam is online now Audioholic Jedi Adam should be listened to
    Join Date
    Jul 2006
    Location
    Tucson, Arizona
    Posts
    26,520
    Thanks Given
    7,584
    Thanks Received
    9,127
    Default
    Before seeing this, I responded in the similar thread here.
    Mains and Surrounds: NHT 1.5s, Center: NHT AudioCenter-1, Subs: SVS PC13-Ultra, SB13-Ultra, Receiver: Pioneer Elite VSX-23, Amps: Emotiva RPA-1, POS-1, Display: Panasonic TC-P50G10
  5. The Following User Says Thank You to Adam For This Useful Post:
    gene (07-11-2012)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
