Page 9 of 234 FirstFirst ... 78910111959109 ... LastLast
Results 81 to 90 of 2340
Thread: Philharmonic Audio - 3-way open back ML-TQWTs designed by Dennis Murphy
  1. #81
    Dennis Murphy is offline Senior Audioholic Dennis Murphy should be listened to
    Join Date
    Oct 2007
    Posts
    502
    Thanks Given
    8
    Thanks Received
    785
    Default
    Quote Originally Posted by AcuDefTechGuy View Post
    Dennis, what is the primary advantage of using Ribbon tweeters vs. cone tweeters and Planar midrange vs. cone midrange?
    Is it basically bigger soundstage?
    In both cases, the theoretical advantage is a driver element with much lower mass. As for soundstaging, the planar dipole is free of any structural frame members that could restrict the rear wave, but I don't think that's a big deal.
    None of this matters, of course. The only issue is whether users will like what they hear. And we'll have to wait a little before there are enough of these things out there to generate meaningful feedback.
  2. The Following 2 Users Say Thank You to Dennis Murphy For This Useful Post:
    AcuDefTechGuy (10-13-2011),DenPureSound (10-13-2011)
  3. #82
    DenPureSound's Avatar
    DenPureSound is offline Senior Audioholic DenPureSound is looking for a job at AH
    Join Date
    Jan 2011
    Location
    On the Pacific Coast, U.S.A.
    Posts
    660
    Thanks Given
    265
    Thanks Received
    151
    Default
    Quote Originally Posted by Dennis Murphy View Post
    HI Any peak at 12 kHz is in the tweeter response, not the planar. The Neo8 is crossed to the tweet at a hair under 3 khz, 24 dB/octave. So the peak has gone bye-bye by 12 kHz. Plus, the peak is really only significant on-axis. The listening axis is above the midrange axis on the Phil. On the low end, the Neo is crossed to the woofer at 650 Hz. That means the planar is operating over a fairly narrow, and for it, comfortable zone. It really doesn't limit the Philharmonics' dynamic range.
    My mistake, I stepped on my toes again. I was looking at the Neo8 Plots and noticed the 12kHz. Peak, but was not thinking that the Xover to the Tweeter was way down at around 2.8kHz. so the slight gain around 12kHz. is being produced by the RAAL Ribbon tweeter, which looks like it is a little more noticeable with a slight gain in db at 0 and 15deg off axis than at 20/30/45 degrees off-axis.
    So the Neo8 Planar really only has to work from 640Hz. to 2800Hz. in the range that the LR 4th order filters put it in.
    Dennis, thank you for clarifying this matter.
    ΩΩ~~~~OHMS~~~~~~ΩΩ~~~~~OHMS~~~~~~ΩΩ
    Main A/V Rm.: Denon AVR-4311CI, Emotiva XPA-5, Def. Tech. BP7001SC SuperTowers, RC-62II, RS-52II, RW-12d and PA-150 Subs, LG BD-590 Player, Technics TT Legacy, DirecTV, Vizio 55" HDTV, Sennheiser RS180 W/L Headphones, and ASUS Android Tablet.
    2nd A/V Rm.: Denon AVR-3311CI, Infinity Classia C336BK Towers, Classia CC225BK Center, Infinity RS-325 Surrounds, Acoustech PL-200 Sub, Sony BDN-470 Player, Samsung 50" DLP HDTV, DirecTV, and AR Cabling.
  4. #83
    Join Date
    Jan 2011
    Location
    Posts
    660
    Thanks Given
    265
    Thanks Received
    151
    Default
    So please explain this DM, are you saying that the sound the brain interprets is different in comparing a Cone Mid/Tweeter driver vs. the Planar and Ribbon Tweeter, even if the cones and ribbons where able to yield the same db gain or loss at those frequencies (hypothetically the same plots)?
    Basically, the tonal qualities of the two for comparative reasons are different, even if they both were to produce the same FR plots? In other words a different sound color?
  5. #84
    Join Date
    Oct 2007
    Posts
    502
    Thanks Given
    8
    Thanks Received
    785
    Default
    Quote Originally Posted by DenPureSound View Post
    I really don't want to make any claims based on physics, since I lack a rich background and this isn't an area of consensus. The idea is that the lower the mass of the driving element, the quicker it responds to transients and the wider the ultimate frequency response (on top). It makes intuitive sense, but I've seen some technical minds dispute the "quickness" theory. I chose the Neo8 because it was a natural dipole and extended upward high enough on and off axis to cross easily to the RAAL 10 mm ribbon. Does the RAAL sound better because it's "quicker." I really don't know. But it does sound considerably more open in an A-B test. And to me the Neo8 sounds as good as the Accuton. But as I said, we'll have to wait and see how much agreement there is.
  6. The Following 4 Users Say Thank You to Dennis Murphy For This Useful Post:
    AcuDefTechGuy (10-13-2011),cpp (10-19-2011),DenPureSound (10-13-2011),frsimms (10-31-2011)
  7. #85
    GranteedEV's Avatar
    GranteedEV is offline Audioholic Ninja GranteedEV should be listened to
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,484
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    Do you find the Neo8 combo to be as 'coherent' as a smaller verti al combo? The CTC spacing of a tall planar and a ribbon near 3khz is definitely bigger than a small cone + ribbon near 2khz... or is this a case of 'on paper vs in execution'?
    FWIW in the industry was saying he thinks the BG Radia which use the same Neo8, were the best speakers he's ever heard.
    As for the RAAL, whatever it is, it has some of the sickest decay/distortion/impulse response that i've seen.
    System: Marantz SR6003
    ---> Crown XLS 2000 ---> Philharmonic Model 2
    ---> Tapco Juice J2500 --> DIY Maelstrom X
    Victory goes... TO THOSE WITH COURAGE!!!
  8. The Following 2 Users Say Thank You to GranteedEV For This Useful Post:
  9. #86
    Join Date
    Oct 2007
    Posts
    502
    Thanks Given
    8
    Thanks Received
    785
    Default
    Quote Originally Posted by GranteedEV View Post
    Is sick good or bad? I was sick last Saturday--bad. The rules for center-to-center spacing don't work too well for planars and ribbons--they behave more like line sources than point sources. I didn't run into any integration or phase issues at 3k--you can see that from the reverse-null plots on my site.
  10. The Following User Says Thank You to Dennis Murphy For This Useful Post:
  11. #87
    AcuDefTechGuy's Avatar
    AcuDefTechGuy is online now Audioholic Overlord AcuDefTechGuy should be listened to
    Join Date
    Jul 2007
    Location
    Krypton
    Posts
    13,570
    Thanks Given
    3,376
    Thanks Received
    3,026
    Default
    Sick, sick, sick and tight, tight, tight is really good.
    REVEL SALON2 . B&W 802D2 . KEF 201/2 (6) . LINKWITZ ORION3 . TAD 2201 . DYNAUDIO X32 . FOCAL 826V . ATC SCM7 . PHILHARMONIC 3 . FUNK 18.0 (2) . RBH SX-1010N (2) . VELODYNE SC600 (4) . PIONEER MM301 (8) . DENON AVP-A1HD/AVR-5308/AVR-3312/DVD-3800BD . ATI 3005/3002/2004/6012 . BENQ W6000 . ADCOM GFS-600 . APPLE TV . KIMBER KABLE 8PR
    My System Photo . My System Video
  12. The Following User Says Thank You to AcuDefTechGuy For This Useful Post:
    GranteedEV (10-13-2011)
  13. #88
    Join Date
    Jan 2011
    Location
    Posts
    660
    Thanks Given
    265
    Thanks Received
    151
    Default
    Grant -- as for the RAAL 70-10D Ribbon Tweeter in the Phil 3's, to me the specs. do NOT look like the sickest decay with more than 13,000 G's of Acceleration in less than 200 microseconds, and after that the Air is Stopped! Now, that is SUPER FAST. What are you looking for 200 NanoSeconds before it comes to a dead stop?
    Sick is OK then you can go horizontal and listen to Music all day long, just don't set the Sleep Timer on.
  14. #89
    GranteedEV's Avatar
    Join Date
    Jul 2009
    Location
    Calgary, Canada
    Posts
    4,484
    Thanks Given
    1,967
    Thanks Received
    2,034
    Default
    To clarify for everyone:
    Sick == Sickeningly Good
  15. The Following User Says Thank You to GranteedEV For This Useful Post:
  16. #90
    Join Date
    Jan 2011
    Location
    Posts
    660
    Thanks Given
    265
    Thanks Received
    151
    Default
    Boy, that changed quickly, thank goodness, LOL. Your good Grant!!
    Ok, GRANT now let's assume we have a 20kHz. input sinusoidal waveform at it's Maximum Voltage (RMS) input imposed upon the RAAL Ribbon Tweeter, how fast (in Micro or Nano Seconds) do we need the driver to be in so that it is back at a Neutral NULL Position before the next forcing cycle comes at it to displace it again?
    Isn't 200 MicroSeconds quick enough, at standard room temp. and pressure of course?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
