Results 1 to 9 of 9
Thread: Paradigm Signature Sub 25 Eliminates Power Conditioners
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Paradigm Signature Sub 25 Eliminates Power Conditioners
    Paradigm Electronics Inc. has started shipping its most powerful and intelligent subwoofer ever: the Signature SUB 25. Recognizing that on-demand power is the essence of subwoofer performance, Paradigm has designed the SUB 25 to effectively harness and optimize AC line current for optimal performance. With the optional room correction system, you've got a sub, its own dedicated power conditioner, and a 4 sub room correction system. Now all you need is a little over $16,000...
    Discuss "Paradigm Signature Sub 25 Eliminates Power Conditioners" here. Read the article.
  2. #2
    sandtrap is offline Junior Audioholic sandtrap is a forum member in good standing
    Join Date
    Jul 2006
    Location
    Saint Louis, MO
    Posts
    50
    Thanks Given
    1
    Thanks Received
    0
    Default Good luck getting 3000 Watts continuous
    Good luck getting 3000 Watts continuous out of a 120V circuit. Make sure you run the 230V if you want to test the amp.
  3. #3
    alexsound is offline Audioholic alexsound is gaining some recognition
    Join Date
    Jun 2007
    Posts
    243
    Thanks Given
    8
    Thanks Received
    17
    Default
    Quote Originally Posted by admin View Post
    9 HZ extention. Amazing. what source material out there goes that low? Anybody?
  4. #4
    GlocksRock's Avatar
    GlocksRock is offline Audioholic Spartan GlocksRock should be listened to
    Join Date
    Oct 2005
    Location
    Charlotte, NC
    Posts
    6,137
    Thanks Given
    287
    Thanks Received
    910
    Default
    Pipe organ music, or the Irene scene in Black Hawk Down... I hear the helicopter blades have some super low bass extension.
    SHARP Aquos LC70LE640U
    Denon AVR-4311ci, Emotiva IPS-1
    APC H15 Power Conditioner
    PS3, Wii, XBOX 360 Elite Slim
    Dell Inspiron 660 HTPC
    Def Tech BP7001SC, CLR3000, BPX, BP10, BP2X
    SVS PB13-Ultra on Great Gramma
    Harmony One
    Bedroom System
    Samsung PN58C590
    Explorer 4250 HD cable box
    Yamaha RX-V1800 Onkyo M-5140 amp
    Xbox 360 Elite, PS3 Slim
    Dell Vostro 400 HTPC
    Def Tech BP7006, CLR2300, BPX
    SVS PC12 Ultra & 20-39PC+ on Subdude HD
    Panamax M8-HT-Pro
    Harmony One
  5. #5
    fredk is offline Audioholic General fredk should be listened to
    Join Date
    Jan 2008
    Posts
    1,289
    Thanks Given
    137
    Thanks Received
    259
    Default
    Pipe organ music
    According to TLSguy the lowest stop on the big pipe organs is tuned to 17Hz. Thats a long way from 9Hz.
    For $16,000 you could build 4 REALY good subs, send them out for pro veneering and finishing and have pocket change left over for a trip or 400 to McDonalds.
    I wonder what the dealer margin is on one of those things?
    Fred
    "Given time, we can come to believe that many different variations on the truth are apparently equally entertaining." - Floyd E. Toole
    _____________________
    Axiom M80 mains, Qs8 surrounds, dual M2 centers, EP350 sub, Sony 50A2020 display, Denon 2808 AVR
  6. #6
    Rickster71's Avatar
    Rickster71 is offline Audioholic Spartan Rickster71 should be listened to
    Join Date
    Jan 2006
    Location
    N.J.
    Posts
    5,518
    Thanks Given
    3,479
    Thanks Received
    3,218
    Default
    Here is some frequency info for anyone so inclined.
    http://www.bookrags.com/wiki/Audio_frequency
  7. #7
    jamie2112's Avatar
    jamie2112 is offline Audioholic Warlord jamie2112 should be listened to
    Join Date
    Oct 2007
    Location
    in a bong
    Posts
    7,869
    Thanks Given
    3,099
    Thanks Received
    2,557
    Default
    That is wwwaaayyyy overpriced.....IMO of course....
  8. #8
    ParadigmDawg's Avatar
    ParadigmDawg is offline Audioholic Warlord ParadigmDawg should be listened to
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    I have 4 of them playing in my room right now.
    Scratch that, turns out to be just one AV Lab Dawg Crusher making all that deep, tight noise in there!!!!!!!!!!!!!
    A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
  9. #9
    Warpdrv's Avatar
    Warpdrv is offline Audioholic Ninja Warpdrv should be listened to
    Join Date
    Dec 2006
    Location
    @ Milwaukee, WI
    Posts
    4,262
    Thanks Given
    640
    Thanks Received
    1,332
    Default
    I'll call BS on Paradigms marketing hype at this point... That sub may be able to produce usable output at 9hz in a closet, but in my 8200^3 room it will offer no advantage to me then one of my single heavy duty 15" drivers.
    9Hz doesn't mean it will have usable output at 9Hz. No single commercial subwoofer can reproduce a 9Hz tone at usable volume (110dB). It also doesn't say whether it is flat to 9Hz, which is impossible without EQ. It can be 15dB down at 9 Hz, which is not so "good".
    I'm sure it has built in EQ but I doubt that sub offers any more linear excursion then my TC3000 or possibly even the TC2000.
    It is very nice to see that Paradigm is stepping up to the plate to replace their long overdue need to upgrade their line of subs. The Servo 15 .v2 is a pretty darn good sub, but Andrew/avaserfi, me as well as others that have used measured super drivers will attest to the superior SQ over that sub.
    Paradigm is a very proficient manufacturer of its own in house drivers, but the price of this sub is reaching in terms of value. JL walked that line and did very well, but in the end you can acquire an F113 for $2200-2300 new with warranty.
    I will be happy to build you a sub that easily performs as well for far less then 1/3 that price...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
