I looked over his site and couldn't find a specific article that dealt with multi woofers in this type of enclosure. Please provide a link. Inquiring minds want to knowI am much less qualified to discuss this than Martin King himself, who just posted above as MJK. I suggest spending some time browsing and reading at his web site. He has articles that specifically deal with mass loading and with dual woofers as in a MTM design.![]()
HT System
Rcvr B&K AVR 507 Amp B&K EX4420 (main speakers) Main speakers Salk SongTower QWT Center Salk SongCenter Surrounds NHT SuperZero Subwoofer DIY PE RS 12" HF 2 ft³ cabinet with HPSA 500 amp BR player Panasonic DMP-BDT500 TV Panasonic TC-L37G1 Phonograph ARxa, Sumiko Oyster cartridge & Audio Technica PEQ3 preamp
SongTower Listening Impressions - Photos
2-channel system
CD Player Sony CDP-591 Pre-amp Marantz 2230 stereo receiver Amplifier B&K ST-140 Speakers DIY 2-way CAOW1
After a quick search, I believe this is it. MJK please correct me if I am wrong.
HT System
2-channel system
Nuance AH should be listened to
My carpet is about 1/4-1/2" thick with a spill pad/cushion pad underneath that is about the same thickness. My SongTower spikes have no issues keeping the ST's solid and wobble-free.
I too thought the spikes would be worthless because they weren't sharp at the end, but after performing a "wobble test" using no spikes vs. spikes, spikes won. The speakers wobbled more without the spikes, surprisingly.
However, go with your gut.
Thats a modeling analysis for 2 driver systems in ported box whether wired in parallel or series from what I see. It doesnt say anything about TL design???After a quick search, I believe this is it. MJK please correct me if I am wrong.
In order to really understand what is going on, I need to see a pic of the enclosure of this speaker. Can anyone provide that? thanks.
Thanks for the review, Tom. I'd heard of these speakers and was glad to be able to learn more about them.
Jim
I did not look at any tube preamps for the same reason that Car and Driver is not reporting on buggy whips. - David A. Rich, PhD
The audiophile reviewer will pick the most warped sound as his reference for sonic purity. - GranteedEV
Receiver: Marantz SR8002 Speakers: Paradigm Studio 20, Studio CC-490, Studio 10 Subwoofer: HSU VTF-3 Mk3 Sources: Oppo BDP-93, Xbox360 TV: Panasonic TC-P50V10
MJK is looking for a job at AH
The analysis presented is for a bass reflex enclosure. But basically it shows the reader how to set up a single equivalent driver which in turn allows them to run my MathCad worksheets for MTM designs in TL's. In the case of the SongTowers, Paul Kittenger used this technique to model an equivalent driver at the tweeter location and then design the ML TL enclosure. Many people have done this and it works very well.
There is no formal hard definition of what is a TL and what is not. If you ask a half dozen TL designers for a definition you will probably get half a dozen slightly different answers. There is a large gray area between what is sometimes referred to as a classic TL, which you seem to be describing, and some of the hybrid TLs like what I call a ML TL. When I look at a design I try and see/calculate what the air is doing in the box, if it is forming a quarter wave length standing wave at the tuning frequency I consider it a form of TL, people have started to call them quarter wave resonators which is probably a more accurate description.
But in the end how it sounds is all that is importent. The only people who really needs to know exactly how it works is the designer and manufacturer so that it comes out right for every happy customer.
bigspur1984 is gaining some recognition
Thanks I will stick with the standard spikes.
I am getting the same finish as the SongTower RT that are for sale right now, the medium to dark curly cherry. I will be sending in my deposit tonight. I am getting the center channel also.
You and Nusance are one of the big reasons I am buying these after reading your reviews. Of course I have never read anything bad about them helps also.![]()
