Results 1 to 9 of 9
Thread: Loudspeaker Power Handling: What's It All About Part I?
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Loudspeaker Power Handling: What's It All About Part I?
    There are two basic ways in which you can destroy a loudspeaker with power; thermally or mechanically. Everyone is familiar with the concept of being able to burn a loudspeaker. It gets too hot, and the voice coil wire burns, or worse, something else (like the cone) catches on fire and burns. We all go shopping with “How many watts can it handle?” This is like living in a vast desert with only a few filling stations and wanting to know your cruising range in miles. We ask how big is the tank, and not how many miles we get to the gallon. (What is the efficiency?) In part I of this series, we examine a few very simple concepts regarding power handling and common misconceptions surrounding them.
    Discuss "Loudspeaker Power Handling: What's It All About Part I?" here. Read the article.
  2. The Following 3 Users Say Thank You to admin For This Useful Post:
    annunaki (12-16-2008),jamie2112 (12-16-2008),zumbo (12-16-2008)
  3. #2
    TICA is offline Audioholics Accounts Manager TICA should be listened to
    Join Date
    Apr 2005
    Location
    Land O' Lakes, Florida, United States
    Posts
    165
    Thanks Given
    74
    Thanks Received
    29
    Default Excellent Job
    Thank you for such easy to read information.
    I can't wait to see what awaits on Part II!
    TICA
  4. #3
    Djizasse's Avatar
    Djizasse is offline Senior Audioholic Djizasse is looking for a job at AH
    Join Date
    Feb 2008
    Location
    Lisbon, Portugal
    Posts
    727
    Thanks Given
    617
    Thanks Received
    156
    Default
    It's not easy to design drivers
    My home office - WIP - [X360 Elite] - [Zalman TNN-500AF with E6600/4Gb] - [4x Tannoy Reveal 6 + Reveal 66] - [Yamaha RX-V861] - [Samsung LE32A656] - [Behringer EP2500 + DCX 2496 + Infinity Kappa VQ gueto build]
    Living Room - [Toshiba EP35] - [Marantz SR-6003] - [2x Monitor Audio RS6 + Monitor Audio RS LCR + 2x Monitor Audio RSFX] - [Samsung LE52A656]
  5. #4
    Davemcc's Avatar
    Davemcc is offline Audioholic Spartan Davemcc should be listened to
    Join Date
    Jan 2007
    Location
    The Satellite of Love
    Posts
    6,561
    Thanks Given
    781
    Thanks Received
    2,529
    Default
    Still over my head. If I revisit this from time to time, it might sink in.
    Dave.
    Dynaudio Focus 140, Era D5 LCR Center + Era D3 surrounds, SVS PB12-Plus, Integra DTC 9.8, Rotel RMB-1075, Toshiba Regza 52", Bell HD-PVR Satellite, Panasonic BD35, Escient Fireball, SMS-1, Panamax 5300EX.
    Some people are like Slinkies. They serve no purpose but still put a smile on your face when you push them down the stairs.
  6. #5
    shf
    shf is offline Audiophyte shf is a forum member in good standing
    Join Date
    Dec 2008
    Posts
    1
    Thanks Given
    0
    Thanks Received
    0
    Default Spk to RMS match
    Will a 100/200 watt pa head run a 200/600 watt rated 10 inch speaker?
  7. #6
    Donna Negus's Avatar
    Donna Negus is offline Audiophyte Donna Negus is an unknown quantity at this point
    Join Date
    Dec 2008
    Posts
    8
    Thanks Given
    2
    Thanks Received
    0
    Default
    yes what is it about these watts I’m confused
  8. #7
    annunaki's Avatar
    annunaki is offline Moderator annunaki should be listened to
    Join Date
    Dec 2003
    Location
    Wausau, WI
    Posts
    4,214
    Thanks Given
    1,045
    Thanks Received
    1,257
  9. #8
    jamie2112's Avatar
    jamie2112 is offline Audioholic Warlord jamie2112 should be listened to
    Join Date
    Oct 2007
    Location
    in a bong
    Posts
    7,869
    Thanks Given
    3,099
    Thanks Received
    2,557
    Default
    Good read thanks....
  10. #9
    peterlonz is offline Audiophyte peterlonz is a forum member in good standing
    Join Date
    Sep 2010
    Posts
    2
    Thanks Given
    0
    Thanks Received
    0
    Default High temp wire enamel insulation
    Have to say most of the reasons against the use of hi-temp insulated wire sounded hollow to me:
    1) the class (or heat resistance) of the wire enamel coating does not influence solderability except perhaps you might need to use Hi-temp solder also.
    2) Obtaining the desired wire & hi-temp coating might take a little extra time, so what, we are in a planned manufacturing environment surely?
    3) What's the problem with Glue, use your standard mix which is not stated to be a component of "the problem".
    If it's necessary to increase the bake time so what, durability & quality usually carry some price & you have a speaker with a somewhat higher rating.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
