Results 1 to 4 of 4
Thread: Yamaha NS-SP7800PN First Look
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Yamaha NS-SP7800PN First Look
    While your budding audiophile may be worried about performance to the exclusion of everything else, many others have other concerns. Aesthetics is probably one of the bigger concerns with first adopters. When you are as worried about aesthetics as sound, Yamaha's NS-SP7800PN may fit the bill nicely for you. You'll get decent sound with surprising bass, a fantastic looking set of speakers that won't detract from your décor (it may even add to it), and it doesn't break the bank while doing so.
    Discuss "Yamaha NS-SP7800PN" here. Read the article.
  2. #2
    admbe is offline Audioholic Intern admbe is a forum member in good standing
    Join Date
    Dec 2007
    Posts
    26
    Thanks Given
    7
    Thanks Received
    0
    Default
    Quote Originally Posted by admin View Post
    Did not see too many comments on this review anywhere. The price has come down, I wanted to know what you guys think how it would pear up with a Sony STR-DG810 6.1 Channel Home Theater Receiver
    Thanks
  3. #3
    Join Date
    Dec 2007
    Posts
    26
    Thanks Given
    7
    Thanks Received
    0
    Default
    Quote Originally Posted by admbe View Post
    Thanks
    OK, well, I went ahead and purchased these speakers. I like them a lot, but the sub is not that great. Highs are crisp, and the bass is good at average volume... But if you want to crank it, the bass starts flapping and sounding like crap...
    I wish I knew more about audio to give you a better review! For a novice like myself, who lives in an apartment, these will be a good purchase.
  4. #4
    furrycute's Avatar
    furrycute is offline Banned furrycute is an unknown quantity at this point
    Join Date
    Nov 2004
    Posts
    1,499
    Thanks Given
    69
    Thanks Received
    23
    Default
    The speaker cones are kind of on the small side, you'll be missing out on some of the upper bass frequencies. And the sub, I think it's only a 6.5inch, good enough for mid bass frequencies, but definitely not up to the job when it comes to real bass frequencies. A small satellite/sub combo like this usually end up with a sizable frequency gap in the upper bass frequencies, because the satellites cannot play low enough, and the subwoofer cannot play high enough.
    But for movies, and non critical listening, this should be okay, you don't usually notice the gap.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
