Results 1 to 2 of 2
Thread: Paradigm 60-SM Rock Monitor Speaker System Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Paradigm 60-SM Rock Monitor Speaker System Review
    The Paradigm 60-SM Rock Monitors are all around solid performers, providing better sound than you might expect from such a conspicuous little package that happens to blend beautifully into almost any outdoor setting. While I sometimes found myself craving a bit more bass extension and dynamics, I couldn’t falter their limitations based on their physical size. As far as I am concerned, they are decorative rocks that double as good sounding eye candy. If you are yearning to take your music outdoors without cramping your style, the Paradigm Rock Monitors should provide sufficient reasoning for you to catch up on your listening sessions while enhancing the enjoyment of yard activities.
    Discuss "Paradigm 60-SM Rock Monitor Speaker System Review " here. Read the article.
  2. #2
    Dan Banquer is offline Full Audioholic Dan Banquer is gaining some recognition
    Join Date
    Jan 2003
    Posts
    351
    Thanks Given
    5
    Thanks Received
    17
    Default Rock Monitors
    "The Paradigm 60-SM Rock Monitors are all around solid performers"
    Yes Gene, but are they solid as a rock performers?
    Sorry about that, I just couldn't resist.
    d.b.
    I was an audiophile until I found out what they were doing in the recording studio.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
