Results 1 to 7 of 7
Thread: Soundolier duo Wireless Speaker Lamp Review
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Soundolier duo Wireless Speaker Lamp Review
    In our experience, wireless hasn't been done right yet and we were hoping that Soundolier would be the first. Soundolier has obviously worked very hard to ensure a stable and strong wireless connection. I would have no problem recommending these speakers to anyone that has décor issues (as long as you don't turn them up too loud) or is just looking for a nondescript way to get background music into a room without the hassles of wires. They are an expensive solution for sure but the ease of setup and the rock solid wireless connection may make that extra money seem well spent.
    Discuss "Soundolier duo Wireless Speaker Lamp Review" here. Read the article.
  2. #2
    JonBaker99 is offline Audioholic JonBaker99 is a forum member in good standing
    Join Date
    Dec 2005
    Location
    Jacksonville, FL
    Posts
    162
    Thanks Given
    0
    Thanks Received
    2
    Default
    But with only 4 channels how am I supposed to run my center channel for my 5.1 lamp setup? Damn looks like I'll have to hardwire that pesky center.
    I actually saw and listened to these at EHX and was reasonably impressed. What I really want to see is just the hardware sold as an outboard solution for wireless transmission and maybe a small wireless powered amplifier, similiar to the KEF wireless setup.
  3. #3
    jake5717 is offline Audioholic jake5717 is a forum member in good standing
    Join Date
    Apr 2007
    Location
    Orange CA
    Posts
    248
    Thanks Given
    1
    Thanks Received
    6
    Default
    So the only way to dim the light is with a foot switch? How hard or easy would it be to keep the "remote" on an end table and control the light by hand?
  4. #4
    Tom Andry's Avatar
    Tom Andry is offline Speaker of the House Tom Andry should be listened to
    Join Date
    Aug 2004
    Location
    Australia
    Posts
    1,321
    Thanks Given
    68
    Thanks Received
    152
    Default
    Quote Originally Posted by jake5717 View Post
    It'd have to be a super low table. The cable on that switch doen't have much play if I remember correctly.
    Tom Andry
    Associate Editor, Audioholics
    Pursuing the humor in audio & video...
    Listen to the AVRant Podcast
    Download my FREE eBook - Bob Moore: No Hero
    Or the full length followup - Bob Moore: Desperate Times
  5. #5
    Join Date
    Apr 2007
    Location
    Orange CA
    Posts
    248
    Thanks Given
    1
    Thanks Received
    6
    Default
    So if they were setup as surrounds you wouldn’t be able to just lean back and turn the light on?
  6. #6
    Tom Andry's Avatar
    Join Date
    Aug 2004
    Location
    Australia
    Posts
    1,321
    Thanks Given
    68
    Thanks Received
    152
    Default
    If you could reach the ground you could. There are no controls on the light itself (other than audio controls).
    Tom Andry
  7. #7
    Join Date
    Apr 2007
    Location
    Orange CA
    Posts
    248
    Thanks Given
    1
    Thanks Received
    6
    Default
    That’s too bad. In cases where you have then as surrounds you’d probably just set it and forget it, therefore making the lamp the more important feature. Real bummer I defiantly would have got a pair to replace my surrounds, but if it’s too hard for the GF to use then it’s not gonna fly.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
