Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Pool side audio connections
  1. #1
    Gordonj's Avatar
    Gordonj is offline Full Audioholic Gordonj has very reliable input
    Join Date
    Apr 2012
    Location
    Va
    Posts
    250
    Thanks Given
    101
    Thanks Received
    51
    Default Pool side audio connections
    Hi Everyone!
    They are getting ready to break ground on our new pool and I need some ideas on a way to have connection(s) for an iPod type device at pool side. The main system would be back in the house and we would have rock speakers around the pool area. I just need some suggestions on connectivity for by the pool. The Idea is to make it easier to select music or change music, etc. I was just looking at some wireless items but just don't know.
    Any thoughts?
    Gordon
  2. #2
    Rickster71's Avatar
    Rickster71 is offline Audioholic Spartan Rickster71 should be listened to
    Join Date
    Jan 2006
    Location
    N.J.
    Posts
    5,516
    Thanks Given
    3,478
    Thanks Received
    3,212
    Default
    I suggest running some PVC conduit to the location you expect to control the audio from, or run it to a few locations. (Just in case a wireless option doesn't work) A separate run for AC and the other for low voltage.
    This may also be an option: Wireless Accessories - Aperion Audio
    There's what people want to hear.
    There's what they want to believe.
    Then there's the truth.
  3. #3
    ParadigmDawg's Avatar
    ParadigmDawg is offline Audioholic Warlord ParadigmDawg should be listened to
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    I just ran a IR repeater from my main system so I have full control of zone 2.
    A bunch of Paradigm stuff, a big sub, a few amps and 3 plasma's...Panny of course...
  4. The Following 3 Users Say Thank You to ParadigmDawg For This Useful Post:
    Gordonj (07-09-2012),Rickster71 (07-09-2012),sawzalot (07-08-2012)
  5. #4
    sawzalot's Avatar
    sawzalot is online now Audioholic Samurai sawzalot should be listened to
    Join Date
    Dec 2006
    Location
    Philly Southburbs
    Posts
    2,194
    Thanks Given
    1,203
    Thanks Received
    948
    Default
    Quote Originally Posted by ParadigmDawg View Post
    The pool is looking good , how is everything holding up since the install ?
  6. #5
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    Quote Originally Posted by sawzalot View Post
    It all really nice. All the landscape is grown up now and we stained the fence a darker color. Looking good.
  7. The Following 2 Users Say Thank You to ParadigmDawg For This Useful Post:
    Gordonj (07-09-2012),sawzalot (07-08-2012)
  8. #6
    Gordonj's Avatar
    Join Date
    Apr 2012
    Location
    Va
    Posts
    250
    Thanks Given
    101
    Thanks Received
    51
    Default
    [QUOTE=ParadigmDawg;893842]I just ran a IR repeater from my main system so I have full control of zone 2./QUOTE]
    That is great. Do you also have any input capability around the pool for an iPod input or dock and if so how did you work that out?
    It looks great!
    Gordon
  9. #7
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    [QUOTE=Gordonj;894009]
    It looks great!
    Gordon
    I don't have any ipod solution around the pool. I play most of my music from my computer which is connected to my AVR. Since I have a display outside, it's easy to navigate. When we are sick of those 5,000 songs, we play either internet radio or someone just pops their ipad or iphone into the AVR and we listen to that but lose outside control of in that case.
  10. #8
    Gordonj's Avatar
    Join Date
    Apr 2012
    Location
    Va
    Posts
    250
    Thanks Given
    101
    Thanks Received
    51
    Default
    [QUOTE=ParadigmDawg;894071]
    Quote Originally Posted by Gordonj View Post
    Thanks PD. I'm just trying to figure a clean and easy way for connectivity at pool side. It looks as though old fashion connections maybe in order. I am looking at a Denon iPod dock that is also wifi. If it works with other manufactures it might work for a portable dock. I probably will still run the cable for audio connections though for safety.
    Gordon
  11. #9
    Join Date
    Nov 2006
    Location
    Hiding from Alex
    Posts
    9,309
    Thanks Given
    2,424
    Thanks Received
    2,630
    Default
    [QUOTE=Gordonj;894118]
    Gordon
    I could have easily ran a cable for an ipad at the same time I was doing the rest but it just wasn't important to me.
  12. #10
    deedubb is offline Full Audioholic deedubb should be listened to
    Join Date
    Oct 2007
    Location
    The Great White North
    Posts
    462
    Thanks Given
    93
    Thanks Received
    154
    Default
    Not what you're asking for, but I use a Soundcast Outcast speaker as it has better bass than any other outdoor speaker I've heard due to the built in sub. I run it wireless using iTunes on my Mac as the source and I control iTunes at the poolside using my iPhone.
    Main Floor HT:
    Toshiba 65" (old school - weighs 2 tons)
    PSB Stratus C6, PSB Stratus Silver, PSB Ambient II, PSB Subsonic III, Harmon Kardon AVR525, PS3
    Basement HT:
    Pics here; more pics
    Pioneer Elite CD Player & Receiver, NAD 7 channel, PS3, Sony VW60, Panamorph lens, Stewart 2.35 Firehawk, Definitive Technology + SVS PB12-Plus/2= 7.1
    Main Floor Audio:
    Parasound P/HP-850, Parasound HCA-1200II, PSB Stratus Gold
  13. The Following User Says Thank You to deedubb For This Useful Post:
    Gordonj (07-15-2012)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
