Dimmable - maybe
I'm all for LED but I need something compatible with the dimmer switches in my home.
I keep reading about these dimmable LED models but I've been browsing alot of vendor brochures and there is a wide assortment of dimming techniques which means there is no guarantee your LED light bulb will work flawlessly with dimmer switches. The most likely scenario of an incompatible dimmer would be shortened life span, which would defeat the purpose.
Some of the better LED manufacturers have a list of tested dimmmers that appear to be compatible but realistically i doubt the tests are extensive enough considering your light bulb is meant to last 30 000 hrs.
Once I start seeing some kind of manufacturer guarantee from dimmer switch companies identifying their product as LED friendly than I'll make the switch (no pun intended), even at today's prices.
That's my 2 cents.
KL
Blu-Ray Player : DMP-BD65
CD Player : Sony CDP-C225
Receiver : Harman Kardon AVR 235
Remote Control : Logitech Harmony 650
Speakers: Boston Acoustics CS 260 II Towers, CS 225C II center
Subwoofer : Paradigm PDR-10
TV : Panasonic TC-54PS14
