Adam (12-28-2011)
There is a 50,000-watt AM/FM station just down the road from me. A while back, I thought perhaps I could get electric power from the station. All I could achieve was lighting a neon lamp by connecting it to the coax of a 175 mile range log periodic FM antenna. There wasn't enough current to do anything more than that.
Take care,
Mark & Mary Ann Weiss
http://www.basspig.com 16,500 watts of driving Surround Sound!
http://www.mwhdvideo.com
http://www.ampexperts.com
Adam (12-28-2011)
I remember some early versions of inductive lamps producing RFI. Now, almost all modern inductive units are under FCC rules.
You wouldn't experience anymore RFI than from a microwave oven or a PC.
There's what people want to hear.
There's what they want to believe.
Then there's the truth.
Rickster71 (01-02-2012)
I have an old lamp that needed some new bulbs. LEDs were on sale, so I picked up two 40W bright white LEDs and they are considerably brighter than the previous 60W soft white CFLs. The bright white 40W CFLs only came in single packs and were only $2 each less than the LEDs, so the cost difference wasn't terribly different in reality.
HT: Emotiva UMC-200, Emotiva XPA-3, 3X GR Research A/V-2s, GR A/V-1s, Epik Empire, Oppo BDP-83SE, URC R-50, APC-H10, Panamax 5100, PS3 Slim120G(500G) Bluejeans Cable
System Two: Marantz SR-8300, GR Research A/V-2s, Sony SCD-222ES SACD, Panasonic BD-65, PS3 60G (250G), My HT
Are you sure which side of the glass you are on?
That's what they said about BPL (Broadband over Power Line). Yet in every city where it was tested, the interference to the 2-80 meter bands was widespread and made communications impossible.
They can shield a lamp, so perhaps it is possible the manufacturer solved the RFI problem, but the very technology is RF noisy to begin with.
Take care,
I had heard some problems with the old style ballasts.
I've only installed them in industrial / commercial locations where RFI wasn't really an issue.
The LED's are aimed mostly at residential customers. All the government funding is going toward LED's, which makes me wonder about the fate of Induction.
Under $5 LED is now on the market. Low on lumens though, so not exactly ready to light the whole home.
http://gizmodo.com/5885653/the-first...s-with-a-catch
