Results 1 to 2 of 2
Thread: Crestron Prodigy PLX3 Remote Control Preview
  1. #1
    admin is offline Administrator admin should be listened to
    Join Date
    Apr 2004
    Posts
    96
    Thanks Given
    0
    Thanks Received
    1,226
    Arrow Crestron Prodigy PLX3 Remote Control Preview
    Crestron finally debuted its new Prodigy PLX3 Handheld Remote Control, its new long range handheld remote solution control for owners of their Prodigy home automation system. The PLX3 was designed to deliver long-range performance while granting custom installers the opportunity to program customized commands into it more efficiently. This means users can have a handheld remote that allows control over lights, thermostats, zone audio, home theaters, remote cameras and more - and from just about anywhere within the home. The PLX3 uses a 2.4 GHz mesh network to increases the range and effectiveness of the home network, allowing signals to go even hundreds of feet through floors and walls.
    Discuss "Crestron Prodigy PLX3 Remote Control Preview" here. Read the article.
  2. #2
    smurphy522's Avatar
    smurphy522 is offline Full Audioholic smurphy522 has very reliable input
    Join Date
    Apr 2005
    Location
    Houston, TX
    Posts
    273
    Thanks Given
    11
    Thanks Received
    37
    Default
    Seems "mildly interesting" (to coin a phrase) for us mere mortals. Noting it cannot be used alone since it works in the 2.4 Ghz realm and requires a media controller gateway to process the signals to I/R. More details and full specs here.
    Press release here.
    From a quick search it looks as though the MSRP for the remote is: $500 USD and the matching gateway media controller is $800 USD. A kit is listed as $1200 USD is also in the works which adds to the above a IR blaster w/pwr supply.
    I am sure the capabilities are numerous and as most Crestron products will require purchase and set-up through an authorized dealer.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
