Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: 12-Zone Multiroom Audio Install Price
  1. #1
    den327 is offline Audiophyte den327 is a forum member in good standing
    Join Date
    Mar 2010
    Posts
    4
    Thanks Given
    0
    Thanks Received
    0
    Default 12-Zone Multiroom Audio Install Price
    I was wondering approx. how much in labor it would cost me to have an audio contractor Wire and install 12 zones of audio throughout my new construction home. To wire all zones and speakers, install keypads,brackets,speakers and program the unit. Labor only. Thanks
  2. #2
    highfigh's Avatar
    highfigh is offline Audioholic Spartan highfigh should be listened to
    Join Date
    Sep 2008
    Location
    Milwaukee area
    Posts
    6,263
    Thanks Given
    16
    Thanks Received
    1,583
    Default
    Quote Originally Posted by den327 View Post
    There's no way to tell without doing a walk-through and knowing what equipment you plan to use. It can't be done and anyone who says they can give any kind of accurate price has either never done a system like that in its entirety or has never programmed one. Approximate price can range from a couple of thousand to tens of thousands because the programming will cost more than the installation labor and some systems take a lot longer to program, test and troubleshoot than others.
    You need to be a lot more specific.
    Never eat anything that squirts out of a machine.
  3. The Following User Says Thank You to highfigh For This Useful Post:
    bandphan (03-03-2010)
  4. #3
    bandphan is offline Banned bandphan is off the scale
    Join Date
    Dec 2007
    Location
    in a haze
    Posts
    6,619
    Thanks Given
    2,890
    Thanks Received
    2,201
    Default
    ^+1 and if your looking for 12 zones how much are you willing to spend and what level of control do you need. Honestly unless your versed in this, pay for a professional company to work it out
  5. #4
    Join Date
    Mar 2010
    Posts
    4
    Thanks Given
    0
    Thanks Received
    0
    Default
    I was thinking about going with the Russsound MCA-C5 system. Thanks for your input
  6. #5
    markw's Avatar
    markw is online now Audioholic Warlord markw should be listened to
    Join Date
    Nov 2003
    Location
    New Joisey
    Posts
    7,506
    Thanks Given
    850
    Thanks Received
    1,917
    Default
    Labor rates vary with location. Your best bet is to set out, on paper, what ypu want and send it to a few local installers and see what yoou get.
    "Knowledge is knowing that a tomato is a fruit; wisdom is knowing not to put it in a fruit salad" - Anonymous
    Some of my systems: http://cgi.audioasylum.com/systems/1606.html
  7. #6
    T2T's Avatar
    T2T
    T2T is offline Senior Audioholic T2T should be listened to
    Join Date
    Mar 2005
    Posts
    667
    Thanks Given
    409
    Thanks Received
    121
    Default
    I'm sure it also depends on which part of the country you live in, too. Labor rates for such an install are going to be higher in/near metropolitan areas and less in areas where labor rates are lower.
    I don't know if your specific question can be answered here in this forum. You might want to contact a couple of local contractors to bid on the job - and, select the one at that point. Of course, you could come back here with the bids to verify that you're not getting ripped off before giving the "go ahead" on the work.
  8. #7
    TLS Guy's Avatar
    TLS Guy is offline Audioholic Warlord TLS Guy should be listened to
    Join Date
    Oct 2007
    Location
    Benedict MN
    Posts
    9,876
    Thanks Given
    865
    Thanks Received
    4,017
    Default
    Think very carefully about whether you really want all home audio. It is an expensive way of getting lousy sound in every room.
    There is a lot to be said for quiet zones, actually most of the house. You really don't need your ears and senses blasted everywhere you go. Just because it is possible, does not mean it should be done.
    My opinion is that you are far more likely to derive pleasure from one good well set up system, than terrible sound coming at from on high all over the house.
    Next issue is that everything has a point of failure, especially those type of systems. Repairs and sorting them out can be complex, and when the system fails totally and has to be replaced, you are in for major sticker shock again.
    So if you think I'm telling you to run as fast as you can away from such a system, I am.
    Marantz DV 9600 Oppo BD-83 Marantz AV 8003 Quad current dumping amps X 7 Direct TV HD 20 HD DVR Carter audio workstation RME Fireface 800 Fujitsu 50XHA40 Front left and right Carter dual transmission line studio monitors MK II. Center Carter coaxial transmission line center speaker Rear Carter NFM-1s Center backs Carter dual transmission line studio monitors MK I. My system: - http://mdcarter.smugmug.com/gallery/...27077317_Pufg7
  9. #8
    highfigh's Avatar
    Join Date
    Sep 2008
    Location
    Milwaukee area
    Posts
    6,263
    Thanks Given
    16
    Thanks Received
    1,583
    Default
    The programming of a system like that has as much to do with the sources as the controller. Are you thinking of buying a system like that online and doing it yourself? Do you have any experience with programming this kind of equipment, or are you trying to decide if you really want a system like this? You need to know that asking your original question and showing only the Russound system isn't enough information to go by when determining an installation cost. The size of the house will determine how much cable is needed, the speakers will determine the amount of labor for their installation and the other equipment and options will all add to the complexity of the system. It has 8 trigger outputs which may be needed- will these be used? A system like this needs Cat5e, speaker wire, it may require junction boxes for the keypads (some localities require these). Running the cables to the KP locations without providing some way of mounting them isn't an efficient way of doing the rough-in.
    In order to be more specific with answers, we need more information from you.
  10. #9
    BMXTRIX's Avatar
    BMXTRIX is offline Audioholic Spartan BMXTRIX should be listened to
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,314
    Default
    A distributed audio system can be done a number of different ways and it truly depends on the level of sophistication of your system. I will completely disagree with the poster above who was talking about lousy sound or failure as a properly designed system will last for decades without any issue at all if you have decent gear.
    12 zones typically would mean two 12 channel amplifiers for discrete amplification, which will run from $1,200 to $2,000 MSRP for new amplifiers, plus your audio distribution unit (preamp), controller, and keypads.
    Keypads typically take a piece of CAT-5 and speakers will typically be run with 14 gauge speaker cabling.
    I would plan on about $120 for labor and wiring per speaker location plus another $70-$90 per location for the keypad.
    That would include cutting in speakers, putting in back boxes for keypads, terminating keypads, and all wiring.
    Keypads would be per unit pricing.
    Speakers, ditto.
    Programming will depend on the complexity of the keypads and the sources.
    As a full example of somethign I would do with new gear:
    2 amps: $1,500 (B-stock)
    Crestron Controller (MC2W) - $400
    Crestron Power Supply: $100
    Crestron 12 button keypads (12): $1,200
    Crestron PAD8 preamp (2): $1,200
    Speakers (your choice): About $100 pair (12 pairs): $1,200
    About 1,000 feet of speaker cabling and CAT-5: $400
    Misc Materials: $100
    Labor: About $3500 total
    Turnkey system with up to 6 individual sources available to each of 12 rooms at your choosing.
    Total: (about) - $9,500 - $10,000 for a fully installed system in NEW construction (pre-drywall)
    But, home size greatly impacts this as would a decision to change speakers to something nicer/cheaper. Inexpensive is $100 pair of speakers which work nicely for room/house music, but some Sonance 622TR speakers which are better will be $150 or so a pair while cheaper ones can be done for under $80 a pair and still sound perfectly fine.
    I've used similar in my home and have had zero issues with my distributed audio for the last five years. One of the big things that can be done is going to a nicer amplifier setup, which costs a bit more, but can be more reliable long term.
    AV Integrated - Theater, whole house audio, and technology consultation during the build and installation process in the Washington DC, Northern VA, and MD area.
  11. #10
    BMXTRIX's Avatar
    Join Date
    Sep 2004
    Location
    Chantilly, VA
    Posts
    5,793
    Thanks Given
    343
    Thanks Received
    1,314
    Default
    Quote Originally Posted by TLS Guy View Post
    I think that people being overly cheap, or looking for excellent audio can really be disappointed, but a decent set of speakers allow for nice background audio throughout a home without the need to blast the 'nice' speakers to be heard during parties or around the holidays.
    Hopefully the blasting will be kept to the rooms designed for it, and this type of system is used for far quieter and thorough immersion in an environment that brings for enjoyable music listening in many zones without any blasting whatsoever.
    Except if you are in the basement, or out on the porch, or in the garage and the three or more hours you spend in that zone you don't get to enjoy any music at all because the really nice setup is located in a completely different location. It is key to put decent audio in every location as appropriate.
    This is why a properly designed and installed system is critical and speaks volumes to the system which is installed. I have (honestly) never had an issue with installations over 3 years old with hardware when I've used decent gear. But, when people have gone really cheap they've had issues within months. The key is going with reliable gear, even if it isn't the most expensive or best at times.
    I certainly don't agree with this. I've definitely enjoyed my home system for the past five years and am looking forward to adding more zones as I finish my basement.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
