Jb Weld {repaired one with it a while back, kind of different than yours but it worked}
Seize is gaining some recognition
Okay, so tweeter magnet came off my MB Quart 280 monitors. It's one of those double-stacked magnet assemblies just wondering what type of glue to use to re-attach it?
Oh and yeah, what would be the best way to align the magnet? Seems kind of tricky since it wants to shift to one side or another.
Here's what the normal tweeter looks like
Here's what the busted one looks like
Picture of the actual speaker
Any feedback/input you guys can give me would me very much appreciated![]()
ImcLoud is considered a mentor
Theater- Emotiva UMC1 pro, ERC2, XPA5 amp, Ascend 340se frnts & cntr, 200se srds, HSU VTF2, PS3, LG 55" LED, & Harmony remote
Whole house system UPA200 amp, vol. controls, d-box, 6 zones- Yamaha speakers
Front parlor-2.2 system- XDA1 dac, XPA2 amp, Pure i20 dock, 2 sw300 subs, WD EVO2-40's
Lwr parlor-2.2 system- Wharfedale Jade 5's, 2 sw300 subs, XPA2
GYM- EVO2-8's, carver monoblox, wd sub
bedrm- Jolida 202 tube amp, tekton lores,D1 DAC
PC-Emo MiniX,CBM170's,12" Sub,D1 DAC
Seize (11-25-2012)
Thanks!
Looks like I'll be headin' to my local car parts store tommorrow to pick some up.
Not to step on Irv's toes but I think I might try a little super glue for the initial aligned bond and then I'd fill that gap between the two magnets with an epoxy called PC-7.
Harry New Year !!!"Never wrestle with a turd. Win or lose, you still end up with sh!t all over you." -Swerd
"any speaker system in your budget will be an excruciating experience" ~ TLS
Seize (11-26-2012)
I have used PC7, {not on magnets, but was at walgreens and picked some up for fan repair at a customers house, and it doesnt like heat, it lasted about a week, before I had to go back, I have never had jbweld come loose} and they have jbweld kwik, high heat ect, plus once you break the seal on that pc7 it doesnt last long for a second use, jb weld can sit on your toolbox for a decade and still be good.... For most things I use CA, but it doesnt like vibration or heat, so I dont think that will be a good match, but the pc7 will probably work as good as anything else...
JB weld is just one of my go to items, they sell it for under water, wood, fireproof ect, its a good product most people have in their garage already... and like I said you can keep it for years vs most of the newer fancy epoxies come in them ez mix plastic containers that mix tip design and you use them once and toss'em... JB still comes in stick or them aluminum paste packets...
Also from years of useing it, I can control the mix, so if I want it to dry faster or harder ect, I can add more hardener or less...
Plus it is delicious on toast...
I used it on a plastic radiator in a Volkswagen Dasher in Texas ... it absolutely loves heat. The product comes in little film tubes so I don't know how many uses you plan to get out of it but it's not expensive and you can get it at Home Depot.
I have more posts so I'm right and you're wrong.![]()
LOL, maybe Im not thinking of the rite stuff, it mixes itself and is like a syringe, correct? and fyi, radiators aren't hot, they are for coolingLOL
I think either way it should work, not really going to get super hot or have a large load on it... bubble gun would prolly work a while..
x3 for JB Weld. I use that stuff on everything and it definitely w/stands heat.
