Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Help on building a in-wall AV rack
  1. #1
    bmurphy2121 is offline Audioholic bmurphy2121 is gaining some recognition
    Join Date
    May 2010
    Location
    Lisle IL
    Posts
    177
    Thanks Given
    14
    Thanks Received
    15
    Default Help on building a in-wall AV rack
    Im getting ready to build my basement theater system for the first time. I think I have everything covered but Im trying to figure about the best way to build a in-wall AV rack. Here is what Im working with. I have the Denon AVR-4311ci, 7" H x 16" W x 17" D, a HTPC 7" H x 17" W x 17" D, PS3 slim 2.5" H x 11.5" W x 11.5" D, and a cable box Im not real sure the size but lets say its a little bigger than the PS3. Im thinking of having a cut out 4' H x 2' W x 2' D. other than that Im not sure if I will have enough room for cables and what not. Is there anything else I should take into account what I may need.
    Thanks in advance
  2. #2
    baniels's Avatar
    baniels is offline Audioholic baniels is looking for a job at AH
    Join Date
    Oct 2011
    Location
    52556
    Posts
    178
    Thanks Given
    35
    Thanks Received
    55
    Default
    Be sure to give proper consideration to ventilation. Leave room for future equipment additions. I would look for examples on this and other forums. Do a google image search for 'in wall av rack' and follow the pictures that look like what you want.
    Are you putting this in a wall that you can access from the other side? I would give anything to have easy access to the back of my equipment.
    L & R
    bdp-93 xpa-2 tx-sr805 50ph9uk minidsp outlaw icbm
  3. #3
    Join Date
    May 2010
    Location
    Lisle IL
    Posts
    177
    Thanks Given
    14
    Thanks Received
    15
    Default
    Quote Originally Posted by baniels View Post
    Ive tried to do a ton of google searches but kinda hard to find a DIY AV rack example. I have tho seen a couple of pics on another forum and got my ideas from there.
    I will be cutting a hole in the wall that will go into one of the basement bedrooms there for ill have good access to the back of the rack. I was also thinkn about putting some sort of door on it so it can hide it when in that bedroom but also allow ventilation too.
  4. #4
    adk highlander's Avatar
    adk highlander is offline Moderator adk highlander should be listened to
    Join Date
    Nov 2006
    Location
    Whiteface
    Posts
    2,922
    Thanks Given
    2,326
    Thanks Received
    1,401
    Default
    I have installed a built in rack in my system. I do have access to the back of the unit to manage cables and such. Will you have access from the back? I built mine as a shelf setup first and then installed middle atlantic rails to give it a clean look.
    Theater Office
    Projector: Mitsubishi HC5500 Screen: 84" Severtson tab tension Display: Westinghouse LVM-42W2
    PrePro: Marantz AV7005 Amps: ATI AT2002/2005 Universal Player: BDP-83 Media Player: C-200 Server: RAID5 8TB
    Mains: Wharfedale EVO2-50 Center: Opus Tri Surrounds: Sonance 623T & SRS1 Subs: Snell ICS-24mk3/LFM-1
    Control: URC MSC-400/MX-980 Lighting: Lutron Maestro
    A diplomat is someone who tells you to go to hell in such a way that you look forward to the trip.
  5. #5
    Join Date
    May 2010
    Location
    Lisle IL
    Posts
    177
    Thanks Given
    14
    Thanks Received
    15
    Default
    Quote Originally Posted by adk highlander View Post
    Yes Ill have access in the back. Its kinda a new build in the basement do to the basement leaking. I had to take a lot of drywall down to find the crack and repair it. So I felt what better time to build my system since I had to replace drywall anyways. I felt that I would build an in-wall rack since everything was already opened up. I like what u did with urs that is what I was looking for was some good examples like that. Any thing to look out for when building it?
  6. #6
    Join Date
    Nov 2006
    Location
    Whiteface
    Posts
    2,922
    Thanks Given
    2,326
    Thanks Received
    1,401
    Default
    If you are going to go with a middle atlantic type of rack I would say you have two choices. I built two 2x4 "walls" for the sides of the rack and then bolted the rails to that. You have to be very exact with the width to get the rails and shelves to fit perfectly. Alternatively you could just get a SLIM 5 rack and mount that on a platform to get the correct height and all of the other dimensions will be set for you.
    Theater Office
  7. #7
    Join Date
    May 2010
    Location
    Lisle IL
    Posts
    177
    Thanks Given
    14
    Thanks Received
    15
    Default
    Ok I have some sort of a design set up. How do I put a pic in here to show my idea?
  8. #8
    baniels's Avatar
    Join Date
    Oct 2011
    Location
    52556
    Posts
    178
    Thanks Given
    35
    Thanks Received
    55
    Default
    Click on the paperclip icon when writing a reply.
    Quote Originally Posted by bmurphy2121 View Post
    L & R
  9. #9
    Join Date
    Nov 2006
    Location
    Whiteface
    Posts
    2,922
    Thanks Given
    2,326
    Thanks Received
    1,401
    Default
    I use a web site of mine to store my photos and link them here. You can use picassa or flckr as well. If it is small enough you can use the attachments button on the tool bar as well.
    Theater Office
  10. #10
    Join Date
    May 2010
    Location
    Lisle IL
    Posts
    177
    Thanks Given
    14
    Thanks Received
    15
    Default
    here is the pic of the plan layout of the basement and some up closes ones of the rack in the bedroom.
    Attached Files Attached Files
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
